is a 2wd pickup lt kit fit on a 93 4runner
Old 02-07-2013, 06:19 PM
renecap's Avatar
does a 2wd pickup lt kit fit on a 93 4runner
as title says will a 2wd trucks kit bolt up to my 93 4runner if its same body style as in same year category??
Old 02-07-2013, 06:26 PM
Toyota~Boy's Avatar
What exactly are you asking.... What kinda kit......
Old 02-07-2013, 06:40 PM
renecap's Avatar
like a total chaos kit along those lines im looking to buy a used kit i see alot for 2wd trucks and their more afordable than keeping 4wd i mean if i get a deal i can do, ill do the 4x but im ok with having alittle more travel and just 2wd basicaly asking if its a bolt on kit will it work.
Old 02-07-2013, 06:41 PM
renecap's Avatar
http://www.race-dezert.com/classifie...tails&id=40405
for example
Old 02-07-2013, 07:09 PM
renecap's Avatar
if anyone can shed some light on this im all ears. i have searched for answer on website and wasnt able to find it on here or other sites aswell
Old 02-07-2013, 07:11 PM
NickMiller's Avatar
I think a 2wd 4runner will need the 4wd lift since it's the same frame/ifs system just WITHOUT the front diff/drive axles if I'm not mistaken... Maybe someone can confirm?
Old 02-07-2013, 07:16 PM
4Crawler's Avatar
The 2WD pickups have a different front suspension than the 4WD pickups (which are the same as the 2WD and 4WD 4Runners). Also, the pickups have leaf spring rear suspension, the 2nd gen 4Runners are coil springs. So likely nothing will swap over between a 2WD pickup and a 4Runner.
2WD pickups use different control arms/ball joints and have the torsion bar attached to the LCA vs. the 4WD pickups and all 4Runners have the torsion bar on the UCA:
- http://www.4crawler.com/4x4/ForSale/...shtml#2WDor4WD
Old 02-07-2013, 07:30 PM
renecap's Avatar
ok so i will need a kit specificaly for the 4wd 4runners. even if i choose to go 2wd. forsure thanks guys if you guys know anyone selling anything in the 1000 to 1500 range let me kno i need everything though for around that price though:/ but im hopfull ill find something
Old 02-07-2013, 09:10 PM
renecap's Avatar
if i modify the kit in the link above can i run it on my 4runner if its 4wd but i will delete 4wd want to use 2.0 coilover so the whole torsion thing wouldnt be a issue right? could this work if so how hard wold it be to put on
Old 02-07-2013, 09:42 PM
Robert m's Avatar
no, it wont work on a 4x4 chassis. that kit isn't even a bolt on kit for a 2wd truck. it needs lots of fab work to mount it with the uppers using heims and not cross shafts.
your $1000-$1500 budget will probably not be enough for a long travel kit for a 4x4 with shocks and axles and anything else you need. keep saving and do it right the first time with a GOOD kit and keep the 4x4 capability.
6th Gear
19
12-10-2019 07:31 AM
voiddweller
19
05-02-2016 09:10 PM
Outsane
06-24-2015 05:52 PM
zytra
06-24-2015 08:14 AM
aec455
07-05-2002 06:05 PM
Quick Reply: is a 2wd pickup lt kit fit on a 93 4runner
