22re question for the gurus
Old Oct 3, 2006 | 06:22 AM
dougm395's Avatar
i bought a 22re out of a 95 4x4 it has 140000 miles and the guy said he had it replaced for low oil pressure. this guy is very wealthy. when i pulled the oil pan off the strainer had some oil sludge on it. im thinking of replacing the timing assy and oil pump. last night i loosened the head bolts on accident. well i was triing to get the rocker arm assy off. so i could pressure wash it. now that i loosened the bolts should i replace the head gasket? i didnt break the seal on the head. also is there a market for a rebuildable 22re complete w/intake and exhaust manifolds? not sure if people buy these
Old Oct 3, 2006 | 06:44 AM
AH64ID's Avatar
I would replace the HG, if your doing the timing chain you have to pull it anyways...
Old Oct 3, 2006 | 07:02 AM
dougm395's Avatar
im a mh60 crewchief
Old Oct 3, 2006 | 07:08 AM
AH64ID's Avatar
sweet, for which service? 160th?
Old Oct 3, 2006 | 08:10 AM
dougm395's Avatar
mississippi national guard ,im full time we picked ours up from 160th
Old Oct 3, 2006 | 08:44 AM
AH64ID's Avatar
good deal, they must be new to your unit. I am thinking of droping a packet for 160th, for the mh-6
Old Oct 3, 2006 | 08:45 AM
norcalsvx's Avatar
i had low oil pressure when my timing chain ate up my cover
Old Oct 3, 2006 | 07:33 PM
millertime_t1's Avatar
I have had good luck with oil pump replacement fixing this problem as long as there is not a "knock"
coleypull15
Nov 3, 2015 07:41 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
thefishguy77
Jul 30, 2015 10:59 AM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
