1987 toyota 4x4 how to get wheel bearing nut off??????
So I'm changing my rotors. Got everthing apart. I turned the wheel bearing nut a couple turns and now its getting tighter? Am I doin somethin wrong or with all the crud is it jammed? I'm confused any help greatly appreciated. Thanx
There is a lock nut and an adjusting nut. http://personal.utulsa.edu/~nathan-b...15componen.pdf You must first open the lock washer, remove the lock nut, and then remove the adjusting nut. If you start turning the lock nut without doing the rest, you'll just turn the pair of nuts until they jam.
91toybeater
12-27-2015 07:46 PM
AustinTaco
06-21-2015 09:54 AM
