1986 22r Starter Relay difference
Old 03-06-2018, 08:52 PM
Matthew Cox's Avatar
I recently purchased a male end starter relay off of a 1986 22r and when I went to put it on my 1986 22r, I realized the starter relay
on my truck was a female end. I was wondering how I can make the male end into a female end like my original starter relay ?
Attached Thumbnails 1986 22r Starter Relay difference-09df885a-5855-48e4-8751-3016f8797775.jpeg   1986 22r Starter Relay difference-0708b3b9-3fc5-4731-9594-aed14a36199d.jpeg
Old 03-06-2018, 09:06 PM
RAD4Runner's Avatar
Take the pigtail/connector off the original and splice it on to the new one.
BUT, why are you doing this?
I doubt if your starter relay is defective. Pls see my signature. In the 6 years I've ben with Yotatech, I have never heard of a starter relay going bad on our trucks except for this
Are you aware of this? https://www.yotatech.com/forums/f199...l#post52297396
Old 03-06-2018, 09:44 PM
My original starter was clicking, so I got a new starter and it ran but then burnt up. What I’ve been told it’s either because the starter relay has gone bad or it’s the ignition switch gone bad. I got a new starter relay because it was the easiest thing to try first and seeing if that was the issue before I went to the ignition switch
Old 03-06-2018, 10:00 PM
RAD4Runner's Avatar
Are you having the issue now? Describe your symptoms in detail and be EXACT; we are not in front of your engine compartment. Exactly what do you see, hear, feel, and where.
My original starter was clicking... it was the easiest thing to try first and seeing if that was the issue before I went to the ignition switch
You have been told wrong.
BUT starter relay was wired wrong AT THE FACTORY. If you don't fix it then your ignition switch may go bad.
The easiest and least expensive thing to do is read this:
Fix your issue for $11.
Old 03-06-2018, 10:04 PM
RAD4Runner's Avatar
To be accurate, please post clear picture of wires going to your starter relay. Show both harness side and relay side.
Make sure you show or note EXACT wire color going to each connector pin.
Old 03-06-2018, 10:18 PM
Ok I appreciate your help, Ill get a better description on what happened, I was with a friend during this and he'll be able to give me better details. Ill get the photos you asked for too later today where I can get better light.
Old 03-07-2018, 11:42 AM
wyoming9's Avatar
Red face
Just get enough spade connectors of the correct gender
Figure out if this is the problem if it is then do a somewhat better job of splicing and weather proofing
Old 03-07-2018, 05:56 PM
I found another female starter relay today, Thank God, so Ill test that one, if it doesnt work out Ill try the wiring solution.
Old 03-07-2018, 08:20 PM
RAD4Runner's Avatar
Cool.
Regardless of whether that relay works or not, you have to verify that is wired correctly. 100% of the 22RE from 1986 to 1989 that I have seen on this forum and at t4R.org had starter relay wired wrong at the factory.
Old 03-08-2018, 06:21 AM
wallytoo's Avatar
you didn't read and understand what ray linked to. the wiring is faulty no matter what part you have or don't have. it is a VERY simple procedure to correct the flawed wiring.
Old 03-08-2018, 11:43 AM
se7enine's Avatar
That reminds me, I need to do Rad's relay mod to my 84 which has no relay. It can go next to the fuel pump relay I recently added.
buckz6319
08-05-2017 03:50 AM
85TRD4runner
11-19-2016 02:42 PM
pistolpete5113
02-07-2012 04:41 PM
Harold Of The Rocks
05-03-2009 10:27 PM
helopilot
08-25-2006 01:46 PM
Quick Reply: 1986 22r Starter Relay difference
