Need info on 22RE-C Performace Camshafts
Old 04-06-2009, 12:13 PM
Stifun's Avatar
Thumbs up Need info on 22RE-C Performace Camshafts
Well I am currently in the process of rebuilding my motor for my 85 Pick UP and was wondering where I could purchase a low-end performance Cam Shaft. My driving is mostly for towing and daily driving short distances.
Thanks For Looking
Old 04-06-2009, 01:07 PM
olharleyman's Avatar
check out engnbldr.com and look at the 261 crawler cam maybe just what your looking for.
Old 04-07-2009, 10:02 AM
Stifun's Avatar
Will do also has anybody heard of
http://www.toyheadauto.com/Performan...alveTrain.html
They make custom camshafts for our trucks any info on this company from anybody.
Old 04-07-2009, 07:42 PM
Stifun's Avatar
Bump for more info on what others have run as far as performance camshafts.
Old 04-07-2009, 07:52 PM
camo31_10.50's Avatar
not sure what they have for the turbo 22RE..but you might check out Comp Cams...type in 22REC or 22RET or 22RTE camshaft..go through the websites it pulls up..thats all i did
Old 06-14-2009, 10:16 AM
yotarover's Avatar
you should check out mizumoauto.com im ordering a timing chain kit tha tincludes, waterpump,oil pump.timing cover, timing kit,2 guides,1 cam gear,1crank gear, 1 tensioner (89.95) seems unreal but i'll let you know if it's worth it. they have head gasket sets for 20.95 as well. but as far as cam shafts go i need a lil more power if you find a decent one let me know
Old 06-14-2009, 02:00 PM
4Crawler's Avatar
I've run a TRD Level 1 cam for about 9 years now, it has worked well:
- http://www.4crawler.com/4x4/CheapTri...shtml#Camshaft
Old 07-17-2010, 01:04 PM
808nickh's Avatar
were can u pick up trd cams ive looked all over the place even ebay
Old 07-17-2010, 01:11 PM
xxxtreme22r's Avatar
http://tinyurl.com/2vhl48f
Old 07-17-2010, 01:16 PM
808nickh's Avatar
wow i feel dumb its on the trd website i must have been blind i cheaked that i swear
Old 07-17-2010, 01:17 PM
808nickh's Avatar
i was reading another forum and the engbldr cam seems to be a good idea to
Old 07-17-2010, 02:47 PM
muddpigg's Avatar
Ran the 261 from EB liked it-put it into a cheap short block threw a rod bearing (nothing to do with cam)
running a 260 delta cam in a performance long block, I like it.
Both had power band were I stay most of the time both on road and off.
Old 03-29-2011, 03:55 PM
87 'runner boosted's Avatar
When doing the cam, did y'all do the timing set as well???
Old 03-31-2011, 08:35 AM
808nickh's Avatar
when i did mine i pulled the whole head off did the head gasket but i had just recently changed my timeing chain and all my tenchioners so i didnt mess with it. i guess it all depends on what kind of condition its in. if there is allot of miles on it you should just replace it, there really not that that expensive i got my kit from engnbldr.
kawazx636
10-06-2021 03:03 PM
TheBFA
02-15-2020 06:55 AM
91yotapup
3.4 Swaps
03-05-2019 10:41 AM
buckz6319
08-05-2017 03:50 AM
White Stripe
10-06-2015 10:47 AM
Quick Reply: Need info on 22RE-C Performace Camshafts
