Adding Intermitent Wipers to an '85 Pick up
Anyone ever added an original (stock) intermitent wiper switch in place of the speeded switch? I know they sell aftermarket kits but I would rather put in a '86-'88 switch out of a 4Runner or equal. How much is involved and which switch goes in the easiest?
Its very easy to do, i added intermitent to my 84 4Runner. you will need the intermitent wiper switch assembly and the relay box, other than that its plug and play, at least it was for me.
So you did change the relay box? Did you have to or did you plan to do it all along?
For the intermitent wipers you have to add the relay box, its not there if you only have regular wipers, there is a jumper wire that you unplug and then you plug the relay box in place of the jumper, this jumper is located above the computer up by the heater blower housing. its kind of a tight spot to get into.
