Adding Intermitent Wipers to an '85 Pick up
Old Feb 5, 2009 | 03:35 PM
Brokenstuff's Avatar
Anyone ever added an original (stock) intermitent wiper switch in place of the speeded switch? I know they sell aftermarket kits but I would rather put in a '86-'88 switch out of a 4Runner or equal. How much is involved and which switch goes in the easiest?
Old Feb 5, 2009 | 10:57 PM
Wardamneagle's Avatar
Wrong year but this might help:
http://forum.ih8mud.com/79-95-toyota...95-pickup.html
Old Feb 5, 2009 | 11:34 PM
85TurboRunner's Avatar
intermittent wipers were an option in 85.
Old Feb 6, 2009 | 06:36 AM
That I did not know. So then I should be able to order the switch from Toyota if it's still available? I think there is also a relay to add? I'll have to check the FSM schematics.
Old Feb 7, 2009 | 12:31 AM
My 1985 4Runner came with intermittent wipers.
Old Feb 7, 2009 | 12:58 AM
Ed H.'s Avatar
I got them on my 84. was it an option then as well? it's an sr5.
Old Feb 7, 2009 | 05:14 AM
waskillywabbit's Avatar
Probably need the column stalk, wiring and the motor perhaps. I bet DC would know or 4crawler.
Old Feb 7, 2009 | 09:51 AM
taconasty's Avatar
i have an extra wiper stalk if you need one. when i have mine on i hear a relay in the pass side, i have no idea whats involved in converting it.
Old Feb 7, 2009 | 02:30 PM
I think everything in principle that he needs to know is in that link that I referenced above.
Old Feb 7, 2009 | 05:29 PM
Originally Posted by Wardamneagle
I had heard that the wiper relay was different for the intermittent switch than the stock switch and he didn't have to change his to work? Interesting. He states that it clicks just like the turn signal relay which doesn't sound right, possibly a little too loud. Should be quieter. Maybe thats why the correct/different relay? I wonder what the original switch/relay sounds like? Maybe quieter? Very helpful advice though.
Old Feb 7, 2009 | 05:57 PM
taconasty's Avatar
mine is factory and it sounds just like the turn relay, it may be in an open location where its easier to hear. idk
Old Feb 7, 2009 | 06:31 PM
Guess I'm just use to my Tundra............
Old Feb 7, 2009 | 06:51 PM
taconasty's Avatar
yea, i don't think sound deadening was a priority in 85. in fact i don't think comfort was a thought either.
Old Feb 8, 2009 | 02:00 PM
myyota's Avatar
Its very easy to do, i added intermitent to my 84 4Runner. you will need the intermitent wiper switch assembly and the relay box, other than that its plug and play, at least it was for me.
Old Feb 8, 2009 | 06:15 PM
So you did change the relay box? Did you have to or did you plan to do it all along?
Old Feb 8, 2009 | 07:13 PM
myyota's Avatar
For the intermitent wipers you have to add the relay box, its not there if you only have regular wipers, there is a jumper wire that you unplug and then you plug the relay box in place of the jumper, this jumper is located above the computer up by the heater blower housing. its kind of a tight spot to get into.
Old Jun 22, 2009 | 06:06 AM
csharp100's Avatar
Wow! Thank you! I was wondering where that relay was! Kinda hard to track down wires without ripping the whole dash out.
Old Feb 12, 2010 | 07:38 AM
rjfortuna's Avatar
Thanks.
Eggslinger
Jun 8, 2019 03:32 PM
okamikai
Apr 30, 2018 10:19 PM
ghostmoney
Jan 28, 2018 11:42 AM
mussy01
Dec 13, 2016 08:20 PM
msane99
Jul 17, 2015 10:13 AM
