| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
22R parts on a 20R
#2 (permalink) |
the only real upgrade to a 20R from a 22R are the block and pistons and carb. most guys swap the 20R head on top their 22R to make a little more power, and the 22R carb since it'll flow more air.
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts past toys: 1984 4x2 1979 4x4 1991 4x4 |
#3 (permalink) |
How would I go about using the 22R carb?
I know the 20R is using an electric fuel pump, and the 22R used a mechanical fuel pump that ran off the cam. Is there a way to make it work off the 20R's electric fuel pump? |
#4 (permalink) | |
Quote:
so i take it the PO swapped in an electric pump or used a tank from a '79 or something? '84 would have came with a 22R with a mechanical fuel pump. LC engineering sells an adapter to bolt the 22R carb on the 20R manifold for about $40.
__________________
#5 (permalink) |
What about swapping over the whole intake manifold, switching to the electric fuel pump as well, but avoiding the adapter? I'm hoping that since I've got all these parts, I can save the pennies where I can.
Edit: Looking for more info, I found out the 20R ports are round, while the 22R ports are rectangular. Can a dremel tool fix this? Last edited by feerocknok; 04-11-2006 at 03:39 PM. |
#6 (permalink) |
the bolt patterns are different as well. really not worth the gain, as the 20R has a better designed intake manifold also.
my setup: 1982 22R block, crank, rods, aftermarket replacement pistons 1979 20R head, bigger valves and some port work offenhauser 20R manifold, weber carb thorley header, DT-542Y(early 22R) works very well, but gets poor gas mileage. i blame that on my shot in the dark carb tuning...i should install an O2 sensor and A/F meter.
__________________
#7 (permalink) | |
Quote:
__________________
Twisted Intentions |
#8 (permalink) | |
Quote:
Grr, so basically, unless I wanna spend a few bucks I can't do anything. Was really hoping for freeness. My J(ust)e(mpty)e(very)p(ocket) is consuming every penny I have. |
#9 (permalink) |
yeah, i know about setting the idle jets, that was very easy to dial in. but to properly tune the carb's primary and secondary main and air jets, you need an A/F meter.
__________________
| Tags |
| 20r, 22r, adjust, air, carb, carburetor, conversion, fuel, intake, manifold, mixture, offenhauser, piston, racing, tune, weberoffy |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 20R/22R Hybridization | Ditchpig | Pre 84 Trucks | 10 | 08-23-2009 09:46 PM |
| 20R/22R Questions | Ditchpig | Pre 84 Trucks | 2 | 07-16-2006 08:59 AM |
| 22r head onto a 20r does anyone know? | ganemeade | Pre 84 Trucks | 3 | 06-25-2006 07:49 PM |
| Nice website for racing parts 20r 22r | -ToYoTa- | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 11-23-2004 08:37 PM |
