| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
1984: Cheap lift
#2 (permalink) |
Lift vs. shackle length:
- http://www.4crawler.com/4x4/ForSale/Shackles.shtml#FAQ4 And yes, given heavy enough strapping (I use 3/8"x2" for mine), and access to large enough drill bits (18mm) that is all it take to make shackles.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#3 (permalink) |
I just did this to my rig, and I used the rear shocks off of a 1997 Ford F150 2wd in the front. Dirt cheap, and plenty of flex for the ~3" of lift I got. I'm still lifting the back, so I don't have any suggestions for you there
![]() And as for shackles, I had good luck using a step-drill bit instead of an actual 18mm drill, I found it cut much easier. |
#4 (permalink) |
Roger- Great information, thanks.
Rally- What center to center length did you use? |
#5 (permalink) |
This was a rears-up-front swap, and I built my own banana shackles. I used 6" center to center of the holes. I don't remember what angle I put them at, but I can find out if you need it. Pictures:
http://www.imagestation.com/album/pi...?id=2097341144 If I had to do it again, I'd probably use 5" though, the angle is good, but not perfect. RallyRoach |
#6 (permalink) |
how many inches would you get from just swapping the rears up front?
are the front and rear leafs the same length? |
#7 (permalink) |
Yu'll get whatever lift you build into the springs:
- http://www.4crawler.com/4x4/4R_suspe...II.shtml#Front Rears are 2" longer than the fronts, center pin 2" farther forward so moves the axle forward as well.
__________________
#8 (permalink) |
thanks for the info
#9 (permalink) |
I have been investigating and triing to choose which method to lift the front, if you use extended shackles in front, the stock shackle is tappred at he bottom, I thought possiblely using straight shackes with washers to fill in gap at the bottom, wondering how solid that would be. you can get lifting shackles from Advance auto or Auto Zone for about 10-15 bucks with nuts and bolts. Rearching springs, but will sag again over time, thinking that adding a couple leafs to front will be the best and safest way of achieveing about 2" of lift for front, will use 2" blocks in rear. By the way, I have a 85 Toy reg cab short bed with 3" body lift, but virginia law is very strict on lift laws... boo!
#10 (permalink) |
I make steel shackle spacers for this purpose:
![]() Can be used loose or welded to the side plates for more strength. http://www.4crawler.com/4x4/ForSale/...l#OrderingInfo
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 1984 forunner body lift | neo | Offroad Tech | 9 | 09-01-2006 06:05 AM |
| Cheap Hi Lift! | deathrunner | General Vehicle Related Topics (Non Year Related) | 10 | 01-23-2006 05:52 PM |
| 4Runner 2.5 lift 4 cheap | shawn | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 12-06-2003 09:01 PM |
| cheap ok lift | MellamoPOUND | 95.5-2004 Tacomas & 96-2002 4Runners | 17 | 11-18-2003 12:05 PM |
| lift on the cheap | 505taco | 95.5-2004 Tacomas & 96-2002 4Runners | 12 | 08-25-2003 09:26 AM |
