1984: Cheap lift
Old Jan 2, 2007 | 09:53 PM
SLC97SR5's Avatar
1984: Cheap lift
I've posted several different threads about this old truck and I'd like to lift it a hair for the time being.
I just made a 1" BL for the cab and a 3" lift for the flatbed.
What can I do for suspension?
Are building extended shackles as easy as measuring some steel strap and drilling two holes?
How much lift does a 2" longer than stock shackle provide on stock springs? 1"??
What cheap lifts/parts have you had success with?
What about shocks, would the Gabriel Hi-Jackers be a viable solution for F&R?
Any pic's of mildly lifted old trucks/4Runners?
Old Jan 3, 2007 | 08:16 AM
4Crawler's Avatar
Lift vs. shackle length:
- http://www.4crawler.com/4x4/ForSale/Shackles.shtml#FAQ4
And yes, given heavy enough strapping (I use 3/8"x2" for mine), and access to large enough drill bits (18mm) that is all it take to make shackles.
Old Jan 4, 2007 | 02:33 PM
RallyRoach's Avatar
I just did this to my rig, and I used the rear shocks off of a 1997 Ford F150 2wd in the front. Dirt cheap, and plenty of flex for the ~3" of lift I got. I'm still lifting the back, so I don't have any suggestions for you there
And as for shackles, I had good luck using a step-drill bit instead of an actual 18mm drill, I found it cut much easier.
Old Jan 4, 2007 | 10:10 PM
SLC97SR5's Avatar
Roger- Great information, thanks.
Rally- What center to center length did you use?
Old Jan 5, 2007 | 11:08 AM
RallyRoach's Avatar
This was a rears-up-front swap, and I built my own banana shackles. I used 6" center to center of the holes. I don't remember what angle I put them at, but I can find out if you need it. Pictures:
http://www.imagestation.com/album/pi...?id=2097341144
If I had to do it again, I'd probably use 5" though, the angle is good, but not perfect.
RallyRoach
Old Mar 3, 2007 | 09:18 AM
gotboostedvr6's Avatar
how many inches would you get from just swapping the rears up front?
are the front and rear leafs the same length?
Old Mar 3, 2007 | 09:56 AM
4Crawler's Avatar
Yu'll get whatever lift you build into the springs:
- http://www.4crawler.com/4x4/4R_suspe...II.shtml#Front
Rears are 2" longer than the fronts, center pin 2" farther forward so moves the axle forward as well.
Old Mar 5, 2007 | 07:14 PM
thanks for the info
Old Mar 21, 2007 | 04:16 PM
mudtoy's Avatar
I have been investigating and triing to choose which method to lift the front, if you use extended shackles in front, the stock shackle is tappred at he bottom, I thought possiblely using straight shackes with washers to fill in gap at the bottom, wondering how solid that would be. you can get lifting shackles from Advance auto or Auto Zone for about 10-15 bucks with nuts and bolts. Rearching springs, but will sag again over time, thinking that adding a couple leafs to front will be the best and safest way of achieveing about 2" of lift for front, will use 2" blocks in rear. By the way, I have a 85 Toy reg cab short bed with 3" body lift, but virginia law is very strict on lift laws... boo!
Old Mar 21, 2007 | 04:35 PM
4Crawler's Avatar
I make steel shackle spacers for this purpose:
Can be used loose or welded to the side plates for more strength.
http://www.4crawler.com/4x4/ForSale/...l#OrderingInfo
Jcrawl94
10
Oct 24, 2015 04:34 PM
Sep 4, 2015 09:27 AM
Ernie217
Aug 14, 2015 05:25 AM
bobpat
Aug 1, 2015 09:25 PM
coffey50
Jul 28, 2015 10:55 AM
