Dropzone's 1981 Trekker Build-Up Thread
Old Sep 11, 2007 | 02:02 PM
  #41
CC_yota's Avatar
Thanks a lot. I tried contacting CBI probably 2 weeks ago and have yet to hear anything back.
Old Sep 11, 2007 | 07:53 PM
  #42
idayota's Avatar
i really like the new rubber. thanks for the pictures of the latches...so they seem secure, huh? do they rattle much? seems like there are better ways to engineer a latch system, but if it works, why reinvent the wheel? cant wait to see what's next!
Old Sep 12, 2007 | 06:20 PM
  #43
WSUWESTON's Avatar
Like your new shoes. Ride is looking great
Old Sep 12, 2007 | 08:47 PM
  #44
dropzone's Avatar
Fossilized
The latches actually don't rattle too bad. I repainted the doors so I still need to replace the rubber pad that was included to keep some of the rattle down. I have seen some people that use a similar latch but weld on extension to the release. Seems to me that you could poke an elbow if it was extended too far. Still might see what I can do with the factory door system just to make it more convient to open the door..
Thanks, looks like you are starting on yours too...Hope the carb rebuild worked out...
Old Sep 25, 2007 | 02:16 PM
  #45
dropzone's Avatar
Fossilized
1.5" Spacers on
I am still looking for a V-6 Rear End to throw on this thing, but in the mean time picked up a set of 1.5" spacers, I was going to need them for the front anyway. I know that a ton of people have put them on, but here are some pictures.. Put them on all four wheels, stability seems a lot better when cornering. I am just going to have to put on some mud flaps soon to keep the law happy.
Before spacers:
After 1.5" spacers:
Now the tires are fairly even with the sliders but stick out a ways:
Old Sep 25, 2007 | 04:06 PM
  #46
Victor's Avatar
Looks good.
Old Sep 25, 2007 | 04:08 PM
  #47
4banginRunner's Avatar
thanks for posting the before and after with the spacers, i was gunna start a thread bout that
looks good!
lucky trekker owners.....
Old Sep 26, 2007 | 02:37 PM
  #48
bigredford's Avatar
rob-
i see you are the one that ended up with one of my old trekkers. call me at 503-799-0666 and i can tell you all about it. i bet the kid you bought it from beat the crap out of it.
Old Nov 13, 2007 | 07:56 PM
  #49
dropzone's Avatar
Fossilized
A little update. Trekker is getting kicked out of the garage again. Something about my wife wanting the space so she can use it to stain some trim for the house oh well gotta give a little sometimes...
So I have gone through a couple of pieces of plexiglass on the back hatch and lexan is way too much. Got a piece of 16 guage or so aluminum from a friend of mine and got to thinking that it might work to use as a frame for the back window which has been a constant pain as far as leaking. Am hoping that what I came up with will help solve it.
Took the frame off and tried to clean it up:
ground off all the old crap and painted it with some rustoleum though I do have a spot that needs to be welded:
Used the cracked back window as a template:
What I ended up with:
I did leave enough aluminum that I can make the opening bigger which is mine plan. The plexi I have seems to be kind of old, kept cracking even when trying to cut it. I ran out of time tonight for paint so I did rough it up with a wire wheel in preparation for paint sometime soon....
Eventually I would like to come up with a way to totally redo the rear hatch, maybe even do some kind of ambulance door type arrangement that would get the lip of the rear down to the cargo floor level. Trekkers came with about a 4-6" lip that makes getting stuff in and out a pain...
Old Nov 13, 2007 | 07:59 PM
  #50
dropzone's Avatar
Fossilized
Forgot, the UPS guy dropped off some stuff from Trail Gear today:
front spring mount, shackles and winch mount:
Hi Steer, u bolt flip kits, rear shock mounts and my favorite--dual case adapter. Hope to have all this stuff mounted over the next few weeks...
Forgot, got it out on the trail a few days ago but ran out of room...amazing how fast blackberries grow...
Old Nov 14, 2007 | 12:31 PM
  #51
idayota's Avatar
i love that you really wheel this thing...nice work!
Old Nov 22, 2007 | 10:36 PM
  #52
dropzone's Avatar
Fossilized
Thanks, I just wanna get it all together and get wheeling more often.
Ganoid (another member) has offered to help me put together the dual cases, having his knowledge will be a big help...
Looks like the aluminum on the rear hatch may only be on for another week or so. Found an ad on craigslist for smoked plexiglass, ...$20..met the lady and went ahead and bought it.. turns out to be this stuff, Makrolon http://www.makrolon.com still had the protective sheet on one side. A little scuffed around the edges but more than enough (need 50x18.75")
sounds like it is very similar to lexan, but made by bayer. same thing that they make some CD's out of , used for headlights and even some roofing...thought for the money it would be worth a shot...
Old Dec 4, 2007 | 03:45 PM
  #53
dropzone's Avatar
Fossilized
found a ton of water=wet carpet
We had a ton of rain monday, about 5 inches, so checked out the Trekker today to find about 2.5" of water in the back...so I knew a bunch had made it up to the front, carpeting was totally soaked...figured that I wanted to rip it out sometime anyway so started cutting away...
Wondered why my carpeting was so nice and plush, found one layer on top of some indoor/outdoor carpeting...yipppeeee
Got the double layers ripped out from the front passenger side and was happy to see a nice basically rust free floor:
Go to the back and found a rusted through spot about 1.5 x3 which should be pretty easy to fix. The metal at the joint with the fiberglass bed is in great shape
Was happy to see the floor in as good as shape as it was as these trucks have a tendency to have swiss cheese floors at times...Won't be able to rip out the driver's sides for a few days...
Slacker (aka: Corey) has found a supplier for new rear hatch seals so I hope to be getting one of those soon to help fix my leaky rear hatch...
Old Dec 4, 2007 | 05:54 PM
  #54
dang, u got lucky with the floor, rust isnt that bad
Old Dec 10, 2007 | 03:31 PM
  #55
dropzone's Avatar
Fossilized
driver's side floor....bad shape
thanks, but got the driver's side carpeting out today, worse shape than the passenger side guess this is what happens from a leaky windshield for who knows how long...get to mess with the body mount
Driver's side rear of the cab, a lot worse than the rear passenger side:
Found three layers of carpeting in one spot this time,
Hope to have this stuff repaired the same time a buddy of mine helps be with the front suspension welding etc...
Old Dec 10, 2007 | 03:40 PM
  #56
dropzone's Avatar
Fossilized
Oh yeah, got rid of the temporary aluminum rear window deal went from this:
To this using some stuff:
http://www.makrolon.com very similar to Lexan..
Here is what I did with a scrap, it flexes pretty dang good so I think I won't be doing my rear window for a long time...just need to see how Corey 's (slacker) rear seal material works out...
No way you get ever do that with plexiglass
Old Dec 10, 2007 | 06:15 PM
  #57
idayota's Avatar
wow, that's impressive. how well does it hold a bend with a little bit of heat?
Old Dec 21, 2007 | 08:39 PM
  #58
dropzone's Avatar
Fossilized
I think that it must hold the bend pretty good, according to the website for makrolon: http://www.makrolon.com/BMS/DB-RSC/M...nsf/id/home_en --they make headlights and other stuff out of it...
Guess I will see if I still have the scrap and try the heat gun on it or sneak into the oven this weekend to see what happens..
Old Dec 24, 2007 | 09:36 AM
  #59
waskillywabbit's Avatar
Looking good Robb.
Old Dec 28, 2007 | 09:23 AM
  #60
dropzone's Avatar
Fossilized
Originally Posted by waskillywabbit
Looking good Robb.
Thanks Brian!
