Differential Pinon Nut
Is there a trick to un-staking the pinon nut? I thought it would be easier to change the pinon seals with the engine out, but I'm having a hard time removing the nut. I'm thinking it might be easier to grind the nut with a dremel tool and use a new one after I change the seal.
I sometimes have luck using a center punch and hammer to uncrimp.
Your idea will work, but don't grind anything except the staked portion of the nut. Grinder vs. pinion shaft = not good. Replace the nut with a new one.
Thanks for the info. I'll try a different punch with more taper to the point and see if that will work. I didn't have any problems on the transfer case nuts, but the diffs are way tougher.
justdifferentials
14
06-11-2017 08:36 PM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
Odin
09-26-2015 06:56 PM
