Pre 84 Trucks 1st gen pickups
32/36 weber installed!
Old 12-13-2007, 04:01 PM
lenwood's Avatar
Talking 32/36 weber installed!
short and sweet,it took 4 hours,no problems besides putting a stiffer return spring in. truck runs like a new truck(81 4x4l/b 232k) good for many more miles. no driveability problems whatsoever. at least for now. best 300 bucks i've spent on my truck in a while.
Old 12-13-2007, 04:28 PM
bleakhorizon's Avatar
did you go with the one piece or two piece adapter......ive gota a one peice now my two peicer kept loosen up so watch it if you got it
Old 12-13-2007, 08:43 PM
808derek's Avatar
good work
Old 12-14-2007, 01:48 PM
lenwood's Avatar
2 piece adapter,but used locking aircraft bolts and blue lock tite. pics possible soon. real straight foward,a little linkage modifications. i'll tell ya,my truck never idled so smooth,....
Old 12-15-2007, 11:51 AM
yota81's Avatar
i've got to do the same thing to my 81...where did you buy from and did you run into any problems?
Thanks
Old 12-15-2007, 12:07 PM
frodin1's Avatar
What air cleaner did you use with it?
Old 12-15-2007, 12:25 PM
ciscojay's Avatar
Those Webers are sweet...had a K&N filter on top. Put one in my old CJ7 and between that, msd ignition and coil it ran beautifully til the day I sold it.
Old 12-17-2007, 12:23 PM
lenwood's Avatar
got the carb from kybwharehouse in wash state. they sell the genuine webers on ebay, not the imitation solexes. 289 shipped. since i live in cali,i bought a stock aircleaner adapter plate from them also so basically it looks stock from a visual look. runs cleaner than the old stocker. pm me if you need more info
Old 12-26-2007, 03:40 PM
fredbauer's Avatar
pm sent
Old 12-27-2007, 07:03 AM
fredbauer's Avatar
Thanks for the link. It will help me a lot. Fred
Old 01-14-2008, 03:44 PM
boobap's Avatar
weber install
did you use your factory fuel pump and regulate it, or did you use an electric pump, or did you just use the stock pump and not regulate it? i am getting ready to purchase the 34/34 and it recommends that the psi be between 2.5-3.5. Do you know what he stock psi is? thanks for any help you can provide.
Old 02-22-2008, 06:26 PM
WSUWESTON's Avatar
I am installing mine tomorrow and I have read that you can just use the stock pump with no regulator. Napa also sells a 3.5 electric pump.
kazuya2416
04-05-2024 02:17 AM
nvdesertrunner
05-11-2020 08:18 PM
God's Bounty Hunter
10-23-2015 09:44 AM
priest16
15
08-06-2015 07:43 AM
mikeyd6789
08-04-2015 11:51 AM
Quick Reply: 32/36 weber installed!
