Your air compressors - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Tool Time
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-17-2008, 09:36 PM   #1 (permalink)
hmmwv15's Avatar
My Dad is looking for an air compressor to get for our garage. We will be running various equipment from it so we need a good all around compressor. Any suggestions as to the specifications or what kind to get?
__________________
I haven't failed, I've just found several different ways NOT to fix this truck. :D
Sean
hmmwv15 is offline
Old 01-17-2008, 10:14 PM   #2 (permalink)
SCYOTA's Avatar
I have a Craftsman 30 gallon compressor and so far it has been great. I got it a few years back for about $300 and it came with an air tool kit. (Sold the tools for about $100) My only complaint is that it is a bit noisy when your running it in a confined space. If you get a 2-stage compressor it will be quieter but will also cost more. I would start by asking yourself what your needs are for the compressor and price range. What kind of tools you plan on using will dictate the CFM rating and take capacity you should get. If you plan on continually running impact wrenches, ratchets, die grinders and things of that nature, get a compressor rated for at least 5-6 CFM at 90 PSI as most of those tools consume that much air if not more. If you have the money I would spring for an Ingersoll-Rand but for the low price Craftsman is hard to beat.
__________________
"WHY DO DRIVE THROUGH ATM'S HAVE BRAILLE?"
SCYOTA is offline
Old 01-18-2008, 04:59 AM   #3 (permalink)
tortis's Avatar
x2 on the craftmans 30 gallon. mines is about 13 years old and i use it a lot. i change the oil in very regular, and keep the air filter cleaned,and tank drained. sometimes i wish i would have bought an bigger upright, but i am happy. i am about to buy a plasma cutter, so it will get used alot more.
__________________
89 Truck X-tra Cab
LCE Timing Chain
31'' Maxxis Buckshot
4.88's built by ZUK(the mind reader)
Aussie Locker Front and Rear
63'' Chevy Springs
Marlin HD Clutch
Bilstein HD Shocks
2.5" Exhaust W/Dynomax Muffler
2-50 Watt Backup Lights
tortis is offline
Old 01-18-2008, 05:12 AM   #4 (permalink)
I have a Craftsman upright, something around 30 gallons. It is great, but noisy, as mentioned above.
Wait for a sale and you will get a bargain.
PCE91V64x4 is offline
Old 01-18-2008, 06:50 AM   #5 (permalink)
111db's Avatar
Send a message via MSN to 111db
I've got a 60 gallon 220v upright from Home Depot, I think its a Husky? It was my moving in present from my dad at my old house, which I bought in 2000. Its always run with no issues. Its pretty overkill for most stuff (impact, nail gun, airing tires) but the additional capacity helps when using something that requires a huge amount of air, like an angle grinder or painting. I think my model is around $400-$500. Obviously not everybody has space for something this large, but I think with compressors the biggest you can go is the best. And get 220v if you have the option.
__________________
Jon
97 4Runner 3.4 * 4.88's * ARB Lockers F/R * ARB compressor * Sonoran Steel numba 1 * 285 BFG AT/KO * TJM 17 * BudBuilt Skids * Stubbs Sliders & BBQ sauce * Irbis out back * Various Electronic Gadgets
111db is offline
Old 01-18-2008, 11:50 AM   #6 (permalink)
4Crawler's Avatar
I have a 4HP/20gal/220volt Campbell Hausfield compressor. Its about 15-20 years old, still works fine. My next one will be a dual stage vertical unit, they flow a lot more air and are much more quiet (and correspondingly more expensive).
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 01-18-2008, 11:57 AM   #7 (permalink)
olharleyman's Avatar
80 gallon INGERSOL RAND stand up best 800 bucks you can spend it is the quite seris and you can hardly hear it when it kicks on and we run a 4post lift plasma cutter and air wrenchs at the same time on this at 125 psi works awsome
__________________
1990 4 runner 5 Speed
Pro Comp Stage II 4" Lift 6" coils rear
Aussie Locker front
5.29's Front And Rear
35 x 12.5 x 15 MT's Micky Thompson Classic II Wheels
Super Charged 3.4 on the way
1993 SAS 4runner 22re 5 speed
4" front 5"rear
5.29's
35 x 12.5 BFG KM'S
Dick cepek DC 1's
88 stock 4runner
3.0 auto
for now
1955 Harley Davidson Springer
Stock 1955 Hardtail Frame
4 Speed
Kick Start Only
1998 Harley Custom Dresser
107 rwhp
139 ft.lbs.trq.
olharleyman is offline
Old 01-18-2008, 02:27 PM   #8 (permalink)
hmmwv15's Avatar
we're looking for something above a 30 gallon capacity. The "biggest" output we will need is to run a sandblaster and a decent paint gun. He has also gotten a lot of good advice from a coleman bulletin board as to what we should get.
__________________
Sean
hmmwv15 is offline
Old 01-18-2008, 02:50 PM   #9 (permalink)
111db's Avatar
Also check Craigslist in your area. Tons of compressors on there, usually decent prices too.
__________________
Jon
111db is offline
Old 01-19-2008, 10:38 AM   #10 (permalink)
4Crawler's Avatar
Quote:
Check the flow rate at the required pressure for your largest load and size the compressor to match that:
- http://www.4crawler.com/4x4/CheapTri...uchAirforTools
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 01-19-2008, 11:10 PM   #11 (permalink)
deserttoy84's Avatar
Send a message via AIM to deserttoy84
Just remember that MOST air compressor are made by Ingersole rand like craftsman,husky,dayton speed air, etc. so dont spend too much on a compressor that looks like all the other brands. Best deal ive found was at home depot. Last time i was there they had a 60 gallon vertical compressor with a couple free air tools and a starter kit with a bunch of fittings for either 300 or 400 cant remember.
__________________
1984 toyota sr5 4x4
22r w/ weber 32/36
Pro comp 4" front springs & 3" rear downey spring
Home made On-board air system
V6 4.88 lock rites F & R
Bilstein 7100 reservoir shocks
deserttoy84 is offline
Old 01-23-2008, 12:06 PM   #12 (permalink)
hmmwv15's Avatar
coolness
__________________
Sean
hmmwv15 is offline
Tags
1993, 30, 60, 80, air, compressor, craftman, craigslist, gallon, husky, ingersollrand, model, number, speedaire, upright
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Air Compressors AH64ID General Vehicle Related Topics (Non Year Related) 21 03-02-2007 10:24 AM
Air compressors at Schucks seafarinman Offroad Tech 3 11-10-2004 09:49 PM
Your opinion on these air compressors rimpainter.com Off Topic Talk 5 09-21-2004 09:15 PM
Air Compressors! ! ? ? ! ? ? ? bayrunner 95.5-2004 Tacomas & 96-2002 4Runners 11 09-06-2004 07:37 AM
Portable Air Compressors dragr1 95.5-2004 Tacomas & 96-2002 4Runners 9 06-09-2004 08:35 PM
2009 InternetBrands, Inc.
