YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Tool Time
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-13-2007, 03:15 PM   #1 (permalink)
Question Q: Air compressor coupling measurements?
I just bought my first air compressor; Campbell Hausfeld 2 Gallon Mini Twin-Stack Air Compressor with 1 1/4-Inch 2-in-1 Brad Nailer / Stapler Kit. So far I've been able to figure out how to operate the machine, but I'm a little lost on the coupling sizes.
According to my manual (for the stapler / nailer) it says to use a 3/8" air hose (for min air pressure of 150 psi) or a 1/2" air hose (for 50' run or longer). I measured the width of the hose that came with my compressor and it's 1/4". The threaded ends measure 1/2". Now I'm unclear about using the hose because obviously it's neither 3/8" or 1/2" (like the manual recommends). This seems odd because it is the hose they included with the compressor.
Also, the manual for the gun says to use a 3/8" quick plug (1/4" NPT threads) with an inside diameter of .315" (8mm) on the tool and a 3/8" quick coupler on the air hose. I measured the plug that goes into the gun (which has an end that snaps into a quick connect plug) and it is 1/2". The quick connect coupler that came with the compressor is also 1/2" (on both ends).
I am measuring the width of the threads. Maybe I'm not measuring correctly? I'm completely unclear what is what with this thing because the measurements I've taken do not match with those recommended by the manual. So I wondering if you can shed any light on this for me. I would appreciate any help you could offer.
Thank you.
desktop is offline
Sponsored Links
To remove this ad, register today!
Old 05-15-2007, 02:25 PM   #2 (permalink)
Anyone??
desktop is offline
Old 05-15-2007, 03:28 PM   #3 (permalink)
4Crawler's Avatar
I run 1/4" (ID) hose on my compressor and it works fine. Most common size hose you'll find. 1/4" pipe thread fittings are also the most common you'll find. They have ~1/2" OD. Maybe if you are planning to run a sand blaster or other high CFM device, 1/4" hose and fittings are fine:
- http://www.4crawler.com/4x4/ForSale/4air.shtml#Chucks
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 05-26-2007, 04:12 AM   #4 (permalink)
Send a message via AIM to skife Send a message via MSN to skife
you know, you could buy a paintball tank like a 45cu 3000 psi tank and regulate it down to the pressure you need for something portable.
__________________
'92 toyota truck
22re, header, 5 speed.
3" body lift, 31" michilin tires
26mm torsion NIB(box of the truck that is)
needs some TLC clean body, i paied $400
skife is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Removing Air Conditioning or converting to air compressor??? NMcruser Offroad Tech 8 11-28-2008 01:46 PM
A/C Compressor turned Air Compressor Kiff 86-95 Trucks & 4Runners 13 08-15-2007 06:59 PM
WTB: pop can sized air compressor (for air horn) Brendan Items Wanted 1 01-03-2007 08:13 PM
Air Compressor this cheap?? callmej75 Off Topic Talk 14 02-22-2006 04:46 PM
I need a compressor for my air horns Brendan 95.5-2004 Tacomas & 96-2002 4Runners 6 11-12-2004 10:18 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
