Rebuild 22RE or not?
I have a 1986 Toyota 4Runner with 150k on the clock. I have the problem where coolant is leaking into the cylinder that is closest to the front of the car. Supposedly that is the timing cover or something like that. Well to take off the timing cover you basically have to take every single thing apart in the front of the engine off.
So, since everything is off should I just buy the $300 rebuild kit from http://www.22re.com so just do everything while I am in there? It would be much easier to do everything while I am in there. I also have done this stuff before so it won't be a big deal for me.
So what do you guys think?
Personally, I'd run a compression check, make sure it's OK and then replace the timing chain, timing guides, do a headgasket, and have the head checked.
If you want to rebuild it - I also recommend Ted (engnbldr) but your costs are just getting started at $300. You're probably looking in the neighborhood of $400-$800 for machine work, depending on the condition of your block.
Dropping a rebuild kit into a used block and well used crank makes no sense to me.
DOnt forget that just cuz the rebuild kit is cheap doesnt mean that the machine work is cheap. You will have to compleatly remove the block from the truck, take it to a machine shop, get it machined, then you can order your rebuild kit since its not unitl after the machining that you will know the size piston to get.
I blew a HG on my truck at 160K, and was debating the same thing you are. The more I think about it the more I am not going to rebuild, just going to slap it back together OE style. Its not that much work to pull a head and timing cover, put a new chain and HG on and get it running again.
http://www.22re.com/main/toy/complete_22r_kit.htm
That is all that is included in the kit.
I think that I am just going to replace the head gasket and then replace everything with OEM stuff. I am not really interested in doing the whole rebuild kit anymore. I took apart the engine and the timing cover looks fine so I don't think it's that. I am thinking it is the head gasket so I am just going to go ahead and replace that. I will give that guy Ted a call and see what he can do for me
Well I took everything apart and this is what I found....
I have the timing chain kit and the engine gasket kit on the way.
The head is being taken to the machine shop tomorrow and the truck should run great by next weekend.
from what ive read it depends on the additives that are in the coolant. Phosphate is added to a lot of cars to prevent corrosion in aluminum heads.
me either. ive been using green w/ jap AL heads for 15+yrs w/o probs
My toyota parts guy says the orange coolant is simply certified silica free, easier on the water pump seals.
Looks like a textbook headgasket case there. Get the head to a machine shop for a rework, clean it all up, reassemble. I like to put all the stuff (plenum, water tubes egr) back onto the head before dropping it onto the block.
If you're thinking about going into the lower end, just pull the whole engine, plan on spending $1200+, replace the clutch, etc.
Well I took the head into the machine shop and they said it was warped. Womp womp. So I got a new head, valves and everything plus a 261 Crawler cam while I was at it. I have the engine gasket set here already and the metal timing chain kit will be here anyday. It should run like a champ once everything is put back together again!
MMA_Alex
25
Apr 18, 2017 05:07 AM
shadowbirdie
Jul 21, 2015 10:38 PM
