Need some info on cluster
Old Nov 8, 2006 | 10:18 PM
all_rice's Avatar
I'm trying to find a sr5 cluster to put into my 93 p/up. The question is do any of them have the gear indicator for an auto trans? I've searched and can't find an answer. thanks
Old Nov 8, 2006 | 10:19 PM
Elton's Avatar
nope there on the shifter its self
Old Nov 9, 2006 | 01:07 AM
all_rice's Avatar
Do you think the speedodometer in my cluster would swap over? I don't want to buy one and it doesn't work. thanks
Old Nov 9, 2006 | 07:50 AM
Elton's Avatar
so the speedo dont work ? you try replacing the cable
Old Nov 13, 2006 | 10:51 PM
all_rice's Avatar
OK I'll try again. I currently have a 93 p/up 2wd extra cab. It's v6 auto. The cluster in there now has the temp, speedo w/gear indicator on it, and the fuel gauge. I want to know if there is a stock cluster out there that has a tach and the gear indicator on it? If not I wanted to know if the I can just swap out the speedo part into the cluster with the tach. The reason for all of this is cause I want a cluster with a tach and gear indicator. Hope this helps.
Old Nov 14, 2006 | 09:04 AM
stock87's Avatar
The speedo assembly is different between the tach and non tach clusters, so I'm guessing you're probably out of luck here.
Old Nov 14, 2006 | 04:06 PM
all_rice's Avatar
So there are no auto sr5's with column shift??:pat:
Old Nov 14, 2006 | 10:49 PM
stock87's Avatar
I suppose it's possible, but you're talking about a rare option on an already rare truck. Don't see that many 2WDs, much less autos. It may exist, but I've never seen it.
Old Nov 15, 2006 | 11:16 PM
all_rice's Avatar
Dam that sucks. well thanks anyway.
Old Sep 23, 2007 | 09:37 PM
stock87's Avatar
Well, sorry to dredge this up from the dead, but damned if I haven't seen the exact beast you were wondering about!
Admittedly, the truck was a 4 banger, but it was a 2WD auto with column shift, and it had a cluster with a tach, and the PRND2L lights across the bottom of the tach.
So they do exist. That's half the battle, right?
TheBFA
Feb 15, 2020 06:55 AM
91yotapup
3.4 Swaps
Mar 5, 2019 10:41 AM
buckz6319
Aug 5, 2017 03:50 AM
White Stripe
Oct 6, 2015 10:47 AM
Jdgarrison
Oct 1, 2015 05:22 PM
