Need some info on cluster
I'm trying to find a sr5 cluster to put into my 93 p/up. The question is do any of them have the gear indicator for an auto trans? I've searched and can't find an answer. thanks
OK I'll try again. I currently have a 93 p/up 2wd extra cab. It's v6 auto. The cluster in there now has the temp, speedo w/gear indicator on it, and the fuel gauge. I want to know if there is a stock cluster out there that has a tach and the gear indicator on it? If not I wanted to know if the I can just swap out the speedo part into the cluster with the tach. The reason for all of this is cause I want a cluster with a tach and gear indicator. Hope this helps.
Well, sorry to dredge this up from the dead, but damned if I haven't seen the exact beast you were wondering about!
Admittedly, the truck was a 4 banger, but it was a 2WD auto with column shift, and it had a cluster with a tach, and the PRND2L lights across the bottom of the tach.
So they do exist. That's half the battle, right?
TheBFA
Feb 15, 2020 06:55 AM
buckz6319
Aug 5, 2017 03:50 AM
