Loud "CLUNK" when turning at full lock...ideas?
Like the title says, sometimes when I'm turning my truck at full lock (either direction) I hear a very loud Pop or Clunk (Descriptive, no?) sound from the front end, sometimes once, sometimes two or three times. It started after hitting a pretty hard pothole while doing some fast trail running one day. Anyone have any ideas? I'm guessing I've got a broken tooth in on one of my front axles or the front diff, but I don't know if that would cause the sound or not.
Thanks in advance!!
Thanks in advance!!
The truck in the picture doesn't have steering stops, the a arms are not stock but that is where they are located. On the lower a arm there is the part that it comes in contact with the circled part. Lube both parts on a regular basis and you will not hear it. There is supposed to be a plastic cap on them but those don't last long.
took me forever to find this thread due to the stupid title but here it is...
https://www.yotatech.com/forums/f2/2nd-gen-4runner-68244/
and if it's not the steering stops, it could be what others are saying in this thread...
"what's that clicking noise i hear when i turn?"
https://www.yotatech.com/forums/f116/whats-clicking-noise-i-hear-when-i-turn-80485/
https://www.yotatech.com/forums/showthread.php?t=80485
That "rubberizer" spray paint? Its made for tool handles and stuff, you spray on several coats and it actually forms a foamy rubber handle...you could spray the end of these stops with that stuff....voila make a permanently bonded rubber cap... work? yes? no?
i think the rubberized would wear quickly....something is needed like a metal roller or a hard polyurithane cap. i think they would do the trick
personally i love the look on people's faces when i make a sharp tunr in a parking lot.....its a mix of
and:cry:
and:cry:
I greased them up & still, CLUNK! There's a groove worn smooth across the middle of both stops; what about taking them off & grinding a rounded top on them? I'm sure it would only be temporary, but would it help?
Ball joint. myne was doing the same thing. kept on embarassing the hell out of me when i was doing donuts cause it sounded like the axle was gonna fall off. but yea, it was the upper ball joint. and she's perfect now.
jasonty
41
Dec 23, 2018 01:00 PM
jerusry
Oct 19, 2015 05:28 PM
MTLroadierunner
Jul 20, 2015 03:07 PM
Hamonacracker
Jul 17, 2015 08:33 AM
