crankshaft seal
crankshaft seal /crankshaft bolt-pully removal
Is the bolt that holds the crankshaft pulley on to the crankshaft of a 1994 toyota pickup (22-RE) reverse threaded or not?????????????
When doing the breaker bar trick like kyle mentioned, you may have to put a little space between the bar and the frame. When I placed the bar right next to the frame and turned the motor, the starter didn't have enough torque to break the bolt loose!
So if you run into that problem, the space between the frame and bar will be that little bit of extra force you need.
BTW, be sure your fuel system is closed or disconnected before turning the engine over.
just happened to run across this forum thread when trying to find the actual SST part used to take the bolt off.... just wanna say THANKS SO MUCH.. ive been trying for afew days to get this off and ... if i didnt come across this id be in the same position... thanks alot!
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
charlie_fong
Sep 27, 2015 10:06 PM
