Location of air intake temp sensor 1990 3vze??
FSM
Yes I checked it and the page I need is missing/dead link. Man I really need to get a hard copy.
I found 3 soft codes 24,31,32, the last two are from me starting the truck with the air meter unplugged. So now I am left wiith code 24, Air intake temp sensor; where is this critter? and how do I test it. if anyone has a link for a howto I would be so stoked!
LOCKnGO
Stuck in MPG hell
LOCKnGO
Stuck in MPG hell
3VZE engine
I think it is EG2-190 even tho it dosent list a code 24. Does it make a difference that my truck is a 1990 model? I'm a little lost here.
I have a 1990 Truck Repair Manual. I finally got all sections. They are as follows:
IN (Introduction)
MA (Maintenance)
EM (Engine Mechanical)
EX (Exhaust System)
EC (Emission Control Systems)
FI (EFI System)
FU (Fuel System)
CO (Cooling System)
LU (Lubrication System)
IG (Ignition System)
ST (Starting System)
CH (Charging System)
CL (Clutch)
MT (Manual Transmission)
AT (Automatic Transmission)
TF (Transfer)
PR (Propeller Shaft)
SA (Suspension and Axle)
BR (Brake System)
SR (Steering)
BE (Body Electrical System)
BO (Body)
AC (Air Conditioning System)
A (Service Specifications)
B (Standard Bolt Torque Specifications)
C (SST and SSM)
D (Electrical Wiring Diagrams)
It looks like the '93 FSM is a bit different. Let me know if you'd like me to look further. By the way, this is the first I've heard of "soft" codes. Do I need to get one of those OBD I Code Readers from Summit?
IN (Introduction)
MA (Maintenance)
EX (Exhaust System)
FI (EFI System)
FU (Fuel System)
CO (Cooling System)
CL (Clutch)
TF (Transfer)
BR (Brake System)
SR (Steering)
BO (Body)
C (SST and SSM)
Avenged
Jul 9, 2015 07:55 AM
