I got a FREE 22re, what would u do to it?
I have a 90 pickup that I am still trying to get to run but that another thread..lol..Any way I just got a stock 22re gave to me by one of my dads friends. What are some low cost motor upgrades to do? Nothing like turbo just simple stuff.
Rebuild the motor, Larger pistions and rings, Master gasket set, new timming chain, oil pump, water pump,
Dont forget the Head, Cam and valves will yield you good results.
all from ted at engine builder
Well efi r alot of wires and stuff to get in the way like my truck now something in the wiring went wroung truck well not run but to tell the truth im thinking of a 87corolla i want to get into drifting alot of my freinds started (www.driftwilkes.com) i know this is a fourwheel web site but i need chep power.
i would rebuild it with the eng builder kit off of ebay for 350, and then do it slowly, thats what i plan to do. you can have someone do a rebuild for you for 2500 here, w/ towing and labor.
Originally Posted by Adams90Toyota
4Hummer about how much will that cost?
Under $600.00 Canadian for my rebuild, and that includes paint, new plugs wires, cap/rotor. vacuum lines,
Pistions, Rings, bearings, Bore the block, master gasket kit, Timming chain, oil pump and water pump. timing chain cover.
$2500 (Are you smoking crack?) some people sure like to throw out usless infomation without having any real knowledge or facts about it
From Teds Site
http://www.engnbldr.com/ToyotaHotLicks.htm
P900 Piston Set (std, .020, .030, .040 available) $60.00
EPNR900 Ring Set (std, .020, .030, .040 available) $31.00
FGS9000 Full Gasket Set ` $60.00
OP900 Oil Pump $53.00
TKS900SR Timing Chain set / Driver side steel rail $64.00
Full Bearing Kit Rods, Mains, TW $60.00
COV900 Timing cover $54.00
Total: $382.00
Total: $382.00
machine shop changed $25 per pistion to bore.
Talk to Ted and he can throw together an Ala Carte Specail
Or
MASTER ENGINE KIT SPECIAL!
$219.00
(less cam / cover)
Master engine kit includes: Pistons, rings, full bearing set (rod bearings, main bearings, and thrust washer set), timing chain set ( OUR engnbldr steel rail kit), oil pump, full gasket set (complete with front and rear seal and OEM style steel clad viton valve stem seals), and brass freeze plugs.
