Panhard & Rear Sway Questions
Old Jul 6, 2006 | 12:47 PM
dwh91102's Avatar
Ok finishing up doing a body lift, bj spacer, and coil lift on a buddys 91 4runner. First question is, how in the heck do you get the panhard bar back on the axle!!!!!!!???? The axle needs to move towards the passenger side about an 1" or more, tryed using a ratchet strap, and that didn't work. 2nd question is, how many of you are running without the rear sway bar, and if so, are you having any kind of problems out of it. Thanks in advance for any replys......Ready to get this thing out of my garage, starting to fell like i'm
Old Jul 6, 2006 | 12:54 PM
Tofer's Avatar
Sponsor
i have ran no sway bars for over a year now... its tipsy as hell but it flexes like mad. if you pull the sway bar kiss any emergancy manuvers / swerving good bye. i still drive mine like a sports car, its just scary.. lol
Old Jul 6, 2006 | 01:19 PM
dwh91102's Avatar
ok that answers that lol Guess he can't be racin. Anybody have any ideas on the panhard???? By the way thanks tofer
Old Jul 6, 2006 | 01:56 PM
mikes350's Avatar
to get it back on i just pry'd the whole body over with a big bar , i know it's not the way to do it but it worked , your going to need a panhard drop bracket to get it back inline properly , do a search loads of good info on it on here
Old Jul 6, 2006 | 02:00 PM
04 Rocko Taco's Avatar
HIJACK...sorry.
With the sway bar issue, if you remove just the front sway bar you can get a lot more flex out of the IFS right? Is it neccesary to remove the rear as well? Or leave it on? I'd like to have my truck be at least a little streetable. Thanks...sorry for hijacking.
Old Jul 6, 2006 | 02:03 PM
dwh91102's Avatar
Pryed on the body I just want to hook the panhard back up for now, I'll check after its together to see if its going to need the drop bracket
Old Jul 6, 2006 | 02:08 PM
mikes350's Avatar
i pry'd between the axle and the brake valve bracket on the panhard bar , just have to be really careful
Old Jul 6, 2006 | 03:47 PM
Tofer's Avatar
Sponsor
can you lift the frame and pull the wheels off the ground nd move it to where you need it to be?
yes, removal of the front sway bar will increase ifs flex.
stock IFS, minus the sway bar.
with a tacoma, there isnt a rear sway bar IIRC, there isnt enough weight back there to need one.
Old Jul 6, 2006 | 04:06 PM
slosurfer's Avatar
If you put the frame up on stands, tires off, with a jack supporting middle of the axle. Then use another jack on the driver side of the axle and lift that side of the axle. Should swing it over a little bit.
Old Jul 6, 2006 | 04:24 PM
Twisty's Avatar
I'm having some issues with my 4runner with regards to the rear sway bar being removed....I've got the BJ Spacers, TJM Torsion Bars, Cruiser Coils, Rancho 9000x shocks, 2" bodylift, and 35's. On winding and twisty roads with a full load of camping gear, the inside front wheel lifts up off the ground while conering........the truck still feels stable when this happens, but you can feel the wheel come off the ground, then come back down once you've exited the corner....mates have followed me and said the wheel was almost 1ft off the ground on occasions.
I will be getting the sway bar link pins lengthed, and then will be re-installing the sway bar, hopefully this fixes it....
As for re-installing the pan-hard rod, I once used a long shovel handle between the tyre and outside of the chassis.....with a couple of mates on it we were able to lever it over enough to get the panhard rod back on.
Old Jul 7, 2006 | 02:21 PM
dwh91102's Avatar
Can we get some video of this
As for the panhard, seem's some good ol pryin is in order when I get off work tomorrow.
the1998sr5
15
Jul 14, 2020 08:35 PM
icentropy
Jul 14, 2015 10:23 AM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
Vargntucson
Jul 4, 2015 12:15 PM
