Timing belt replacement
Old Jun 2, 2006 | 01:39 PM
travelinman's Avatar
Question Timing belt replacement
I'm about to roll 89K on my 4runner and I'm wondering how important it is to replace the timing belt before 90K as per Toyota. Does anyone have any recommendations on this...can I go another 5K without too much danger of blowing it?
Thanks!
Old Jun 2, 2006 | 01:53 PM
bigacuralvr's Avatar
There are a ton of posts, including one about how many miles people have on their original belts. I changed mine out at 95k while adding a S/C. The timing belt was amazingly easy, after figuring out the crank bolt!! You can go until the belt snaps, and nothing bad will happen to your motor...but I really hate being stranded on the side of the road, so I changed mine.
Brett
Old Jun 2, 2006 | 02:11 PM
eric-the-red's Avatar
The best time to change it is the day before it breaks
Old Jun 2, 2006 | 03:07 PM
Crux's Avatar
https://www.yotatech.com/forums/f2/how-many-miles-your-3-4l-timing-belt-55233/
Old Jun 3, 2006 | 06:33 PM
MTL_4runner's Avatar
Ditto to the above, 90-100k is no problem.
I do mine when convienent within that time interval.
Old Jun 3, 2006 | 06:34 PM
E1's Avatar
E1
Didn't change mine til 121k also did water pump and front seals just because. No issues prior I just didn't want to push it, and was going out of town that week so the Runner would have sat. Don't be scurrrd 90K is recomended not law.
Old Jun 3, 2006 | 07:08 PM
Thanks!! I won't sweat it too much then...
Old Jun 4, 2006 | 08:05 PM
youngbuck's Avatar
Is it recommended to change the camshaft seals and the idlers or the idler bearings? I have heard this recommended for other vehicles, particularly the idlers, but I'm not sure if this applies to the 5VZFE.
Old Jun 5, 2006 | 03:01 AM
SouthernComfort's Avatar
I went 145,000 on mine before it was changed and when I took the belt off it still looked good. Just change it when you have a Saturday or Sunday you don't mind spending wrenching on your car, no rush.
voiddweller
19
May 2, 2016 09:10 PM
stagger_lee
Mar 29, 2016 06:27 PM
layifioren
10
Jul 6, 2015 02:26 PM
marcusSRG
Jun 27, 2015 07:13 AM
infinityisfive
Jun 16, 2015 06:51 PM
