Dissolve Intake/EGR Carbon?
Is there a product (other than a chisel) to break up or dissolve carbon built up inside intake port to EGR. '88 22re has a bit at egr and carb cleaner doesn't appear to be dissolving carbon. Also want to clean carbon I can't see inside port. Thanks in advance.
Remember the EGR has a rubber diaphram (SP) in it.....
I bought a gallon can of carb soak/ cleaner with a basket inside.
I proped up the EGR so rubber pieces would not be effected.
Other parts I soked in brake cleaner.
and the intake I used oven cleaner.
Have fun.
VR
Repo
Have fun.
VR
Repo
Mineral spirits. Let it soak overnight (no rubber or plastic parts) and then clean out with a wire brush. If the passageway is completely plugged, I'd try to at least make a hole though the passageway with a wire first, then the soaking can do a much better job. Good luck.
justdifferentials
Just Differentials
14
Sep 24, 2017 08:32 PM
