Removing oil dip stick tube on 22RE
i had the same problem with mine. all i did was take a pair of pliers and carefully move the tube around, then when it gets looser it should just pop right out. it took me about 10 minutes to get it loosened up. just work at it
bryan
bryan
You can remove it if you *carefully* drive it out with a large punch from the bottom side of the block. (The pan needs to be off to do this.) Place the punch on the lip of the tube where it inserts into the block and tap it out. Do this gently or you'll curl the lip closed. Use the largest punch that will fit the hole in the block.
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
