spare tire removal without tool kit...
you can do it by hand... use a cresent wrench and turn the rod... i've done it before when it was too much of a PITA to get the tools out. this is assumeing its not rusted closed. although this might differ between the models.
you can get a piece of rolled steel rod from the hardware store, then bend a crank handle into it. when that's done, weld a piece of 1/4" flat bar to the end of the rod to engage the slot in the holder.
There is no way to reach the cranky thingie on the older designs - *something* has to reach in there to engage the crank. The crank handle is like 3 feet long. I used the crank from my F150 - it has a hook on the end that hooks onto a ring on the screw jack. It worked fine. (no rust.)
If it's rusted, it may not matter if you have the tools or not.
There are two kinds. One the rod goes in at an angle into a little gearbox on the driver side. With this one you can use the cresent wrench idea (I recommend vice grips though). This type uses a cable to hold the tire. This kind is A LOT more prone to getting rusted than the other kind...
Straight in. There is no gearbox, etc - the rod goes straight in. You will have to have something to stick through there. This type uses a chain to hold the tire.
If you can't get the winch mechanism to work, the thing to do is let the air out of the tire (hopefully they mounted it valve stem down, otherwise this gets a little interesting) and press it up with a jack and a board across it. This will give you a very slight amount of slack to be able to cut the cable/chain and free the spare tire.
My 92 runner uses cable and an offset gear box that drives a second shaft.
my 94 truck uses a direct drive (straight on) and cable. Ive had my cable break when 4wheeling. It currently is holding the tire on with two hardware store horeshoe clamps.
Ah HA! I just remembered where those metric bolts laying on the work bench came from (been driving me crazy!) They held the spare tire winch. Glad that's cleared up...
chain style spare tire removal
I don't have any of the tools, and what I found to work was a water meter shut off tool with the prongs bent to make a single bar at the front. Worked great for me. Hope this helps someone.
Found a solution, no spare removal tool kit, Toyota Hilux spare removal.
Just joined this forum because I found a solution.
Our Toyota Hilux has the chain system that holds the spare under the bed. The car did not have a tool kit in the cabin,
Here goes.
1. Remove the metal rod that holds the hood open, if you manage to get it loose without breaking the plastic that holds it in place, you can put it back afterwards without breaking anything.
2. Stick the curved S part into the hole where the spare removal tool should go (rear above bumper) and stick it in the mechanism.
3. Use a crescent wrench, pipe wrench or anything that can hold the other side of the rod, to turn the rod. If your mechanism is not rusted stuck, this will lower your spare.
I had a toolbox with a bunch of stuff but nothing that could reach through the hole in the rear of the car to the turn thing. I could fit wrenches in from under the car, but could not get enough leverage. I was stuck on the rough side of our island at 4AM, no road service. I came to this forum on my phone and read the posts. Figured I needed some kind of long metal rod that would work as the tool. I started looking for a long piece of metal that I could get off this car. After about 30 minutes it came to me. The thing that holds the hood open. Luckily our mechanism was not stuck and the tire lowered. I swapped it out, it still had some air and we got home safely. It was a nice moment. Hope this helps someone someday.
Here goes.
i use this to get to mine after crackheads bent the receiver so bad i cant get the original tool to fit.
https://www.harborfreight.com/24-in-...der-64153.html
24" or longer
24" or longer
Oh, one additional word of warning:
About 7 years after my '87 was new, I looked under the back and noticed my spare tire was missing. "What?! Who stole my tire?!" I thought. Nope. The bracket that connects to the lift chain and fits into the spare tire's rim had rusted away. I can only imagine the drama behind me when that tire fell flat onto the roadway and tumbled in front of someone.
I replaced it with a simple angle-iron bar. Two bolts to line up with the lug nut holes, and an eye bolt to connect to the chain.
Check the bracket for corrosion.
CZ Eddie
35
May 3, 2005 05:03 PM
