Proper torque for Wheel bearings
I am a rookie in car repair. I need some infos How to repack front wheel bearings correctly without over torque and burn the bearings. I plan to take out the Brake disk for resurfacing and re install. I appreciate any write-up or inputs you might give me.
Thanks.
Thanks.
I just did mine and used the following write-up:
http://www.off-road.com/toyota/wheel_bearing.html
Good Luck!
Troy
Good Luck!
Troy
That's an awesome writeup! I need to do my pads and bearings soon too. Are there any parts that one needs besides bearings? I thought I remembered reading somewhere that the locking tab washer thing was a one-use deal. Oh, and is the spindle nut socket just a plain 54mm/2 1/8" socket, or is it special? I needed a four-pronged socket for the hub nuts on my old Ranger, for instance.
Brian
Brian
Brian
Brian
Brian
Brian
Brian
Brian
Good Luck!
Troy
jasonty
41
Dec 23, 2018 01:00 PM
sabine
Jul 18, 2015 03:59 PM
Jnkml
Jul 6, 2015 01:20 PM
