CSI or battery?
Old Dec 5, 2005 | 06:42 PM
Fink's Avatar
CSI or battery?
My Runner has been having a tough time starting, yeah yeah I know it's cause it's cold out but it shouldn't be this tough, I'm almost thinking its my Optima only having 550cca's.
It cranks pretty weak but when it starts its strong...not sure if its the CSI not giving it enough fuel at first so it doesn't seem like its not cranking right or its mainly a weak (as in not a very high cca rating) battery...ideas?
Fink
Old Dec 5, 2005 | 06:43 PM
Localmotion's Avatar
I had some trouble with mine, but ended up being the termials that were corroded. so i cleand them up, got some new bling bling gold/brass ones and it works great
Old Dec 5, 2005 | 06:45 PM
Fink's Avatar
Did you get your terminals online or locally? Either way, brand and what gauges can they handle? I've been debating whether to go ahead and go that route or not...maybe this is the time.
Thanks man,
Fink
Old Dec 5, 2005 | 06:53 PM
I got the terminals locally.
they look like this
I got them at advanceautoparts
Old Dec 5, 2005 | 07:10 PM
Fink's Avatar
Sweet...how do they hook up with the battery wires? What's the wing nut for?
Fink
Old Dec 5, 2005 | 07:17 PM
Fink
the cables have connectors with an o-ring?. the wingnut tightens on the o-ring
for some reason, i just got a craving for onion rings..mmmm
Old Dec 5, 2005 | 07:20 PM
Fink's Avatar
LMAO...that sounds really good actually, dangit...
Hmm, I might have to go look at Autozone and see if they have anything like that.
Thanks for the help man, I'll keep an eye out.
Other than that, what else could be the problem guys? Battery just not strong enough for the winter, bad CSI (if there is one), bad starter...??
Fink
Old Dec 5, 2005 | 08:09 PM
superjoe83's Avatar
550cca is pretty low, your '99 does not have a CSI, cold start enrichment is handled by the regular injectors
Old Dec 5, 2005 | 08:15 PM
Fink's Avatar
That's what I was thinking...sounds like its not really a problem, its just the battery having a low cca rating.
Wonder if I should consider getting a stronger battery...I wish the 3rd gen could accomodate a bigger Yellow Top.
Fink
Old Dec 5, 2005 | 08:21 PM
superjoe83's Avatar
how cold is it getting?
Old Dec 5, 2005 | 08:23 PM
Fink's Avatar
Not near as cold as it will...I would guess this morning it was probably high teens maybe low 20's. Overnight low was easily in the teens not sure what it was when I actually tired to start it, I'd say 20's or so.
Fink
Old Dec 6, 2005 | 04:34 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
Just a thought.. what weight oil are you using? If the battery is not quite up to it AND the oil is too thick, well, you know...
And thanks, guys. Now I have to eat onion rings today. HAVE to...
Old Dec 6, 2005 | 06:45 AM
4RunnerFever's Avatar
My optima 34r says 800 cca on it.
Old Dec 6, 2005 | 07:30 AM
HAHAHAHA. I'm going to Buffalo Wild Wings tonight for wing night and of course, the Onion Rings....mmmmm
smilen724
13
Nov 8, 2015 04:11 PM
Chicken12
Oct 14, 2015 03:54 PM
Gone Fission
Oct 7, 2015 12:42 PM
mreagen
Oct 5, 2015 04:27 PM
JPV
Sep 28, 2015 03:15 PM
