22r carb help!
22r carb help!
I've got a 90 pu with the 22r. It's been stumbling occasionally when driving a consistent speed. So, I put some higher octane fuel in it to see what would happen. Well, it seems worse now. So, I popped off the air cleaner and, well, pardon my ignorance (I'm used to 4 bbl carbs), but this thing seems to have one jet and 2 intakes? Is that right? Anyways, the intake, without the jet in it, is mostly closed (butterfly valve) even when warmed up.
SO, all that to say: Is this a vacuum problem? Is this valve run by the EGR? I need ideas here... thanks in advance.
While warming up. On a cold engine after you turn on the key(not cranking yet),you should step on the throttle fully a couple times. That should close the choke fully, then start it up. the truck should run at high idle for maybe 2-5 minutes then kick down automactically, opening the choke butterfly.
Sounds like your choke isn't working correctly.
2wds were available carbed until '90 or '91
on a lot of the carbs, the secondary choke flap stays shut until you mash the throttle. that's why putting on a weber 32/36 often increases performance, since the carb isn't operating at full potential.
if your engine is stumbling at constant speed i might check the EGR system to make sure it's functioning properly.
buckz6319
Aug 5, 2017 03:50 AM
Toys4parts
Sep 26, 2015 01:56 PM
