quick change cv mod write up?
Not a writeup on how to do it.. but while you have them out you may want to consider doing this easy future time saving mod.
http://www.off-road.com/toyota/cheaptricks/quickcv/
reread your subject.. that may even be what you were looking for.
Yes, being able to get those bolts out would make it A LOT easier. Unfortunately, on the passenger side of my '93, they are on the diff side. You'd have to take the whole front end apart to get them to the press
I don't know if what I did was a bad idea, but I got them out using a hammer and an aluminum bar (could find a brass bar when I looked for it at the hardware store). 3-4 good whacks and they came out OK.
I got all mine out without removing anything from the truck. I did them one at a time by rotating the cv until I had a stud at the six-o-clock position and used a good C-clamp to press a stud out and replace it with a grade 8 bolt. Actually IIRC I think I was able to file down the ribs on the shoulder of the stud and reuse them. You may also have to turn them around, check for clearance by turning the CVs 360 deg. Also use thread locker so the nuts can't back off, could get messy if the bolt started to back out as the bolts could hit other parts as the CVs are spinning.
I looked at mine and it looks like I reused the factory studs on the drivers side, but I wasn't able to on the pass side. IIRC you can reuse the studs by turning them around (the holes are bigger on the nut side of the CVs) but you still need to lightly file the ribs on the shoulder of the stud. On the pass side there is less room to turn the studs around and I had to use metric grade 10.2 bolts and nylock nuts. You may need to cut the bolts or studs down in length for clearance.
I pretty much had to disassemble the hub when I replaced a CV shaft what a PITA I think next time I'll knoch the bolts out of the diff side first would make it alot easier..Hey AW1090 I am usually free on weekends if you need a hand.
Originally Posted by Stump1883
Would this mod work on a 3rd gen with ADD. I can't tell what I'm looking at by that picture, but I would love to be able to pull and axel w/o dropping the spindle. I've done enough to where that is only a 20min job now, but I would love to make that even quicker.
I'm lovin the info I'm getting here guys.....I'm interested in srv1's response, but will have to get underneath the truck before I could visualize if it would work or not......Hey lunnzz, I'd down for some help this coming weekend, but I won't be doing this....I'll be replacing the rear qtr. glass and rear window. Let me know if you wanna help out and I grab the drinks...
Originally Posted by SRV1
Why not weld a hardened nut to the backside of the hub so you only have to take bolts out and not having to worry if the bolts come loose.
James
James
James
James
Originally Posted by mt_goat
Locknuts and loctight, no worries.
James
Originally Posted by tc
Have to do the driver's side CV now (already done the passenger side) and want to do this while I'm under there.
What size bolts do I need to replace the studs with?
the best plan ive heard is just take the stock studs and grind the ribs off them and re-use them. then you dont have to spend $40 for new grade 8 hardware like i did
