Siping Tires in Desert Climates?
Anyone here that lives in AZ, NV, NM or any hot/arid climate sipe their tires? Does it offer any advantages in our climate?
Not too much snow here in Las Vegas in the wintertime...
I would also think that dry hot roads would quickly deteriorate siped tires. But AJ, if you're having good results I might take a look at it.
Actually, I'm waiting until these tires wear out so I can put some Goodyear or BFG M/T tires on...
I have Bridgestone Dueler A/T Revos aka the Yotatech standard issue tires...
Additional siping is mostly beneficial with an agressive MT or a Swamper because they do not come with any type of siping, just large lugs.
Siping Article
I had a chance to watch Goodyear, Toyo, and BFG siping tires at the CORR event held down here. It was fascinating, but looks like a chimp with a hot knife could do it. It seems like siping the right pattern just comes from trying it enough times. If only I had that much money to blow on tires
They have basically a really hot 1/4"-1/2" wide blade that they set the depth on and just gouge sections of the lugs out. It took them abou 10-15 minutes per tire and they had 4-6 guys doing it at each booth. There were enough rubber chunks laying around that I thought about collecting them and retreading my AT's when they wear down
Pretty interesting and I'm sure beneficial, but definitely moreso on aggresively treaded tires.
I sipe all my MT tires, no need for any special tools outside a utility knife:
- http://www.4crawler.com/4x4/CheapTri...reSiping.shtml
I find it helps traction on rocks, on wet pavement and of course on snow and ice. As mentioned, siping helps the tread run cooler and is supposed to make it last longer. If done right (keep siping away from the ends of the tread lugs), no problems with chunking or unusual wear.
FS[PacNorWest]: Parting 2000 4Runner Limited 4WD Marysville, WA
DeathCougar
Apr 1, 2018 11:29 PM
RammerX
Aug 29, 2015 01:10 AM
mr_manny
Jul 31, 2015 10:39 AM
DrZero
18
Jul 24, 2015 11:31 PM
