2nd Gen parts
2nd Gen parts and Transmissions
All parts from 3.0 v6
91 4runner a/c compressor-$65 + shipping
Water pump(without oil cooler) + fail safe thermostat (fails open not shut)- $45
Knock sensor+new wire-$50 *SOLD*
Oxygen sensor-$45 *SOLD*
Front drive shaft-$25 *SOLD*
Rear driveshaft (auto tranny)- $30 *SOLD*
2 Distributors-$50 each
Crankshaft pulley w p/s pulley-$40
PS Pump- $45
Fan Clutch- $25
Also still have an auto tranny/transfer a340h for $250 and one with 300k on it for $50, pickup prefered. * TRANNY SOLD*
The water pump,thermostat, o2 sensor, knock sensor wire were all replaced during my headgasket change. The block is cracked so I'm swapping in a 3.4. All thoses parts have 0 miles on them, but I ran them at idle for about 2 hrs total time. I tested the knock sensor according to the manual and it tested good. 1 Distributor was bought from a yard to replace mine with a bad wire.
I may have other parts I can't think of now.
PS Pump- $45
Fan Clutch- $25
Dang. You should've got me to ship it with the engine brace. Check ya PM.
Still have most parts. O2 sensor and front driveshaft are gone.
Do you have the idler pulley assembly in the center that the power steering & alternator belts turn on? The fan is also on that.
If you remove the fan & the pulleys, there's a plate with a bearing that those pulleys bolt too. I need that assembly. Zip is 34997 if you have it.
Thanks,
Phil
Thanks,
Phil
Do you have a pic of what you're talking about? When I get home today I will look at the engine and try to see what it is. I'm pretty sure I have it.
The last two pictures on this page are what I'm looking for. The first picture is the bare shaft and assembly. (There is a stud missing on the right side. I figured a BFH & some PB blaster might free that up, didn't work) The 2nd picture shows how the pulleys mount on it.
http://pg.photos.yahoo.com/ph/pjohnsey/album?.dir=8237
Thanks,
Phil
Thanks,
Phil
Driveshaft is in good shape with usual greasyness. I can't say that it vibrated at all cause I've driven my Runna at 90+ mph and did'nt have any vibration. It isn't damaged, the only reason I removed it is cause the manual driveshaft is 2" longer.
Thanks,
Phil
Thanks,
Phil
Driveshaft weighs about 20lbs. My zip is 30530 for shipping.
Would $50 shipped be good for you for the driveshaft? Thats what a few other people are offering.
thanks!
Lamm
thanks!
Lamm
thanks!
Lamm
thanks!
Lamm
Somebody must want this tranny. $250
One tranny is sold. 300k is only $50 or going to the crusher. Also have a 91 a/c compressor for $60. Rear driveshaft is pending.
Updated
No problem Lamm. I hope it runs perfectly for you man.
Do you have a Toyota Denso Starter. Not a Reman starter a Toyota Denso starter for a 91 Runner with the 3.slow 4wd 5spd.
nezsm76@yahoo.com How much shipped to 32244
Need ASAP! Thanks
Steven
Need ASAP! Thanks
Steven
sorry usmcracing no starter.
