2nd Gen parts
Old Oct 3, 2005 | 10:48 AM
hektikwon's Avatar
2nd Gen parts and Transmissions
All parts from 3.0 v6
91 4runner a/c compressor-$65 + shipping
Water pump(without oil cooler) + fail safe thermostat (fails open not shut)- $45
Knock sensor+new wire-$50 *SOLD*
Oxygen sensor-$45 *SOLD*
Front drive shaft-$25 *SOLD*
Rear driveshaft (auto tranny)- $30 *SOLD*
2 Distributors-$50 each
Crankshaft pulley w p/s pulley-$40
PS Pump- $45
Fan Clutch- $25
Also still have an auto tranny/transfer a340h for $250 and one with 300k on it for $50, pickup prefered. * TRANNY SOLD*
The water pump,thermostat, o2 sensor, knock sensor wire were all replaced during my headgasket change. The block is cracked so I'm swapping in a 3.4. All thoses parts have 0 miles on them, but I ran them at idle for about 2 hrs total time. I tested the knock sensor according to the manual and it tested good. 1 Distributor was bought from a yard to replace mine with a bad wire.
I may have other parts I can't think of now.
Old Oct 8, 2005 | 03:26 PM
callmej75's Avatar
how much ya charge me to ship that water pump to 24301?
Old Oct 9, 2005 | 05:58 AM
hektikwon's Avatar
Dang. You should've got me to ship it with the engine brace. Check ya PM.
Old Oct 22, 2005 | 04:29 PM
hektikwon's Avatar
Still have most parts. O2 sensor and front driveshaft are gone.
Old Oct 27, 2005 | 07:49 PM
dusty98's Avatar
Do you have the idler pulley assembly in the center that the power steering & alternator belts turn on? The fan is also on that.
If you remove the fan & the pulleys, there's a plate with a bearing that those pulleys bolt too. I need that assembly. Zip is 34997 if you have it.
Thanks,
Phil
Old Oct 28, 2005 | 08:28 AM
hektikwon's Avatar
Do you have a pic of what you're talking about? When I get home today I will look at the engine and try to see what it is. I'm pretty sure I have it.
Old Oct 28, 2005 | 09:02 AM
dusty98's Avatar
The last two pictures on this page are what I'm looking for. The first picture is the bare shaft and assembly. (There is a stud missing on the right side. I figured a BFH & some PB blaster might free that up, didn't work) The 2nd picture shows how the pulleys mount on it.
http://pg.photos.yahoo.com/ph/pjohnsey/album?.dir=8237
Thanks,
Phil
Old Oct 28, 2005 | 09:03 AM
4x4Lamm's Avatar
How is the rear driveshaft, did it vibrate at all or was it damaged?
Lamm
Old Oct 28, 2005 | 11:34 AM
hektikwon's Avatar
Driveshaft is in good shape with usual greasyness. I can't say that it vibrated at all cause I've driven my Runna at 90+ mph and did'nt have any vibration. It isn't damaged, the only reason I removed it is cause the manual driveshaft is 2" longer.
Old Oct 28, 2005 | 11:39 AM
hektikwon's Avatar
Thanks,
Phil
I have a couple at home. When I get home today I'll make sure it's the same exact kind, then I'll pm you a shipped price. You need the whole fan drive pulley assembly.
Old Oct 28, 2005 | 05:01 PM
hektikwon's Avatar
Driveshaft weighs about 20lbs. My zip is 30530 for shipping.
Old Oct 30, 2005 | 02:43 PM
4x4Lamm's Avatar
Would $50 shipped be good for you for the driveshaft? Thats what a few other people are offering.
thanks!
Lamm
Old Oct 30, 2005 | 05:54 PM
hektikwon's Avatar
thanks!
Lamm
Pmed ya!
Old Oct 31, 2005 | 03:32 PM
hektikwon's Avatar
Somebody must want this tranny. $250
Old Nov 3, 2005 | 06:38 PM
hektikwon's Avatar
One tranny is sold. 300k is only $50 or going to the crusher. Also have a 91 a/c compressor for $60. Rear driveshaft is pending.
Old Nov 8, 2005 | 04:43 PM
hektikwon's Avatar
Updated
Old Nov 8, 2005 | 05:39 PM
4x4Lamm's Avatar
Got the driveshaft today. Thanks! In great shape.
Lamm
Old Nov 8, 2005 | 06:09 PM
hektikwon's Avatar
No problem Lamm. I hope it runs perfectly for you man.
Old Nov 12, 2005 | 11:04 AM
usmcracing's Avatar
Do you have a Toyota Denso Starter. Not a Reman starter a Toyota Denso starter for a 91 Runner with the 3.slow 4wd 5spd.
nezsm76@yahoo.com How much shipped to 32244
Need ASAP! Thanks
Steven
Old Nov 14, 2005 | 05:41 AM
hektikwon's Avatar
sorry usmcracing no starter.
