Where is my anti-freeze going???
Old Oct 2, 2005 | 06:31 PM
cracker_1's Avatar
After checking the antifreeze the other day and seeing it low (1.5 gal. added), I assumed the PO had messed up. I also changed the oil (filter was on finger tight) and checked the spark plugs(they seemed loose as well). Everything looked o.k., but I am still smelling antifreeze up front. I can't find/see any leaks. No drops on the ground. Re-checked the Antifreeze level, and it looked low. Could the water pump be going bad? Is there anything else that is prone to antifreeze leaks on the 3.4?? I smell it mostly around the engine and in the cab, going down the road. I can't smell it in the exhaust (thankfully). Where O where is my antifreeze gone...
Old Oct 2, 2005 | 06:42 PM
Localmotion's Avatar
I kind of have the same problem. whenever im on the throttle, i smell this burning odor. Im not sure if its oil or antifreeze. Id say get under the rig and look for a leak, theres bound to be one somewhere. I have a heater hose? that is leaking some antifreeze.
Old Oct 2, 2005 | 10:12 PM
jimbo74's Avatar
head gasket failure.....
Old Oct 3, 2005 | 05:33 AM
GreeneHoosier's Avatar
Check your floorboard and see if it is wet. Could be a heater core. Check the freeze plugs. Check overflow tube/container for leaks.If it is not in your oil then it is probably not your headgasket. Headgaskets sometimes (rarely) leak to the block side instead of the piston side... Put something down when you park for the night and check it carefully in the morning before you have major engine damage or a stranded situation. Good luck.
Old Oct 3, 2005 | 07:40 AM
Yota4runner's Avatar
Check the clamps on your lower rad hose, I have one come lose and start to leak awhile back.
Old Oct 3, 2005 | 01:58 PM
cracker_1's Avatar
The floor boards are dry and no smell in the cab with the windows up. Will check the overflow bottle/hose. No fluid in the oil or on the plugs, so I don't think it is the head gasket. You can smell it around the engine, so it is leaking somewhere in the engine compartment. Nothing on the floor at night, I park over cardboard to keep the floors kinda clean. Where ever it is coming from, it is small and on/near something hot to generate the smell.
Old Oct 3, 2005 | 05:24 PM
BeaterToyota's Avatar
My anti-freeze seemed to be disappearing without leaking, dripping, etc. I kept refilling it, but there was never any spots or puddles under my junk.
I bought a new radiator cap and everything is back to normal.
Old Oct 4, 2005 | 06:55 AM
cracker_1's Avatar
I can try that approach, as I washed the engine compartment yesterday and last night I checked around the engine for any signs of a leak. I also added the Bars Stop Leak and conditioner to the radiator just in case. I am goignt o watch it more closely for now on and see what happens. I will rpelace the cap as well. Did you have to buy it from Toyota?
Old Oct 4, 2005 | 01:28 PM
Nope. Just a cheap one from a parts store. They're like $5.
Old Oct 5, 2005 | 07:00 AM
cracker_1's Avatar
Well, after adding the Bars stop leak/conditioner, the smell has gone away. So, something, somewhere was leaking... I will still continue to look for the leak, rather fix it than patch it w/ Bars.
Old Oct 11, 2005 | 06:48 PM
Ontario's Avatar
I also had disappearing fluid and smell that would come into the cab when my windows were down but no signs of leakage on my driveway. I had a leak from the hoses leading into the heater core, driver side near the firewall. I replaced the clamps 2 weeks ago and it seems to have done the trick.
Old Oct 11, 2005 | 07:04 PM
Jared Ajlouny's Avatar
could be the water pump.....mine was leaking
Old Oct 12, 2005 | 05:39 AM
Blair's Avatar
I'd suspect the casting plugs, probably the ones at the back of the engine, burried under the bell housing. I had a similar leak a while back. People will tell you that the Stop Leak does more harm than good, but it worked (and continues to work) for me with no plugging or other fouling. I'll replace all of them when I do the clutch.
Old Oct 12, 2005 | 09:19 AM
brandontrek's Avatar
my coolant is leaking right out of the top of the radiator somewhere...all i know is that when i refill it...i have a nice little puddle in the channel on the top of the rad...
Old Oct 12, 2005 | 09:54 AM
celica's Avatar
The 2nd gen 4runner is notorious for leaking rads in this location. The antifreeze ends up etching through the top of the rad.
I have gone through a rad this way, then the secons the soder wasn't that good.
Matt
Old Jan 14, 2006 | 10:50 AM
uh oh...i think i have this problem. The drip is around my bell housing too.
any recomendations as to what to do/fix?
Old Jan 14, 2006 | 12:49 PM
MTL_4runner's Avatar
That could also be the headgasket because most of the time it would leak towards the rear part of the engine where it was tough to see. Did you ever have yours done in the recall?
Old Jan 14, 2006 | 12:50 PM
they only checked it..no replace
erwatt
Jan 3, 2011 06:59 PM
mldave
Jul 26, 2010 07:36 PM
Quattro15
12
Mar 12, 2008 05:49 AM
psychobillyman
Sep 1, 2006 10:30 AM
timmie
Aug 24, 2006 03:23 PM
