truck tells me rear hatch is open, but its not
As of a few days ago, my dash light is on indicating that there is a door ajar, and the rear dome light is on as if the rear hatch is not closed, but it is.
2 questions
1- where is the sensor in the back door telling the truck the door is open/closed?
2- this day I also mistakenly left my keyfob out in the rain briefly. I doubt this has anything to do with it, but does anyone know if this could affect the RS3000? The remote no longer works, so I will have to program my backup one, but just making sure..
thanks YT
2 questions
thanks YT
Originally Posted by rowdy4runnin
bump. i also have this problem and the alarm annoyingly goes off at random times because of it. i looked around but found no sensor? anyone know where it is on the 3rd gen?
Originally Posted by ajutan
It happend with me, found one of a tiny switch connected to lock/unlocked assembly. just removed it and no more problem.in the schematic this switch conecting to the ground.
so the switch is in the actual lock? and where does this ground to.. would by chance have a schematic? this just started to happen, and may just be related to a bunch of rain/snow freezing in all the lock mechanisms...or maybe my ground is screwed. thanks
The switch is connected to/part of the latch mechanism. I tore the latch apart and lubed everything but still the same symptoms. I am replacing the entire latch to see if that is the culprit.
You might check the actual parts that make electrical contacts and see what is preventing them from operating. Might just need some minor adjustments to make it work right. I think the Door Open switch is tied to the rear door lock button.
Ya i think its just cause it froze up pretty bad. The sensor thinks that the door is locked so this only fails to bring up an open door light, and the cargo light when on the door setting. the autollocks and keyless entry still work. I figure the sensor/button may be frozen down, so would go at it with a hair dryer outside..so the sensor is in the exterior lock mechanism then?
I have the same issue....
I see no one has posted to this thread since 2005. Well, I have the same issue with the rear hatch door ajar light on my 96' Toyota 4-Runner Limited. I had it looked at by the auto-body place after a 75 year old Eastern Hemlock fell on it (still recovering from that), and they oiled it up and can get it to turn off if they pinch the handle just right. Problem is it turns on again with the first bump i hit while driving. Any ideas on how to permanently resolve this?
Looks like I just joined the, my-door-ajar-light-won't-turn-off club. '97 runner SR5...has anybody actually figured out how to fix this dern thing yet? My tail light fuse also just started blowing. The only thing out of the ordinary is that I spliced in a wire to illuminate my relocated license plate, but all the connections check out and there's no exposed wire...help please!
duckhead
170
Nov 13, 2017 06:07 AM
cchinny
Jun 25, 2015 08:11 PM
Beavah
9
Nov 12, 2013 07:31 PM
