Old Apr 21, 2016, 01:31 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Towing & Hauling Guides
Print Wikipost
front tow hook
Old Jul 11, 2005 | 08:33 PM
northfacer581's Avatar
front tow hook
anyone have an additional front tow hook on the left side? im looking at putting one there cuz i found one laying around, and i was wondering if anyone has put one there cuz im having difficulty finding the right place to bolt it on, id rather not have to weld it on...its a 99 4runner
thanks
Old Jul 11, 2005 | 09:09 PM
jimbo74's Avatar
not sure... but on the earlier trucks, the holes are already there for the towhook on the left side.... mounts using the same bolts and hook even as the right side
Old Jul 11, 2005 | 09:42 PM
EWAYota's Avatar
theres a thread that just started today or a few days ago, post your cheap mods or something like that. someone added a 2nd tow hook on there.
Old Jul 11, 2005 | 09:46 PM
jimbo74's Avatar
that thread is this one, however its on a 89... https://www.yotatech.com/forums/f123/show-us-your-best-cheap-mods-62861/
the vehicle in question is a 99... as i mentioned earlier not sure if the frames differ or not between the earleir trucks and the later trucks, but it was definately possible to mount a stock hook onto the left side with no modifications
my truck is an 85 and 4x2 and had no hooks, i bought standard tow hooks and installed them with no problems at all
Old Jul 12, 2005 | 07:19 AM
eric-the-red's Avatar
thanks
I put one on my 2001 4Runner, just unbolted the factory tie-down bracket and bolted the hook on there. You need longer bolts though.
Old Jul 12, 2005 | 02:24 PM
thanks...yea i was wondering if you could just add the hook to that loop but i guess ill just take it down...cuz on the right side there is the loop and the hook...how did you get inside the frame to tighten the bolts?
Old Jul 12, 2005 | 02:28 PM
Fink's Avatar
They welded nuts on the back side, just thread the bolts through and tighten em down. I put a second one on my 2nd gen...I just took both loops off and had just the hooks on there...it was easier to hook up to them that way.
Fink
Old Jul 12, 2005 | 02:35 PM
sounds good...ill work on that tonight...im also putting on a trailer hitch that i picked up, hopefully it will be fairly easy install, it says it will fit a 95-03 taco, so i figured itd fit the 4runner, if not, thats where the fun comes! after getting stuck pretty bad a week ago and only have the one factory tow hook as a means of recovery, i figured itd be a good idea to invest in some recovery points...ive picked up a d-shackle to put on the hitch, and picked up that second hook, so now the only thing left to do is save for a tjm and warn winch! thanks for the help...maybe ill put up some pics when i get done
Old Jul 13, 2005 | 06:54 AM
Fink's Avatar
Pics are always a necessity!
Fink
Old Jul 13, 2005 | 07:37 AM
bamachem's Avatar
you'd be better off getting some shackle hangers from http://www.sonoransteel.com
those hooks can be dangerous if used incorrectly...
Old Jul 13, 2005 | 08:28 AM
87TurboYota's Avatar
I have three on mine.. Two hooks and then a friend of mine always raves about how good the old two wheel drive trucks circular hole cut out hooks are so I added one of thos to the driver side two hook.
Old Jul 13, 2005 | 08:39 AM
well id like to have enough money to get those shackle hangers, but i think my hooks will do just fine. im working on the project right now, the hitch is providing some problems...the instructions say a 1/2" bit is needed...ive drilled the holes, and the bolts dont fit...and i dont have anything bigger, so ive got to make a trip to home depot...but im looking at getting the warn receiver shackle to put in the hitch, pics will be coming though, i promise
Old Jul 13, 2005 | 12:05 PM
updates on the hitch install! we have had to put a hault on the install because of rain and the fact the 4runner wont fit in the garage with the roof rack...lots of pieces, dont think well have to use it all though
weve got one bracket on the left side, and were working on drilling the holes for the other bracket when the rain started
Attached Thumbnails front tow hook-hitch1.jpg   front tow hook-hitch2.jpg   front tow hook-hitch3.jpg
Old Jul 13, 2005 | 04:12 PM
alright all finished up with the hitch...it looks a little goofy because of the body lift, but it will serve its purpose well! front tow hook should be completed in a few days, pics to come
montanatruck
Feb 26, 2017 07:07 AM
whereAreMyPants
Jul 22, 2015 03:32 AM
shadowbirdie
Jul 21, 2015 10:38 PM
1996Taco
Jul 20, 2015 12:02 AM
88yodabasket
Jul 13, 2015 01:32 PM
