Center dashboard space
Old 05-05-2005, 03:11 AM
Blizzard's Avatar
Hello,
Seeing pics of american or japanese 4Runners I've noticed that some have room enought to put two DIN radios.
I'm studying the possibility of installing a car PC in my truck and I've the problem of the screen. If I take off my current player I could put an in dash touch screen, but these screens are expensive.
Normal touch screens are quite cheaper and can be fitted in a double DIN dash.
My 4Runner seems to have a piece of plastic to convert the room in one DIN socket, but if I'd take the plastic off my hole isn't yet a double DIN...
Looking at the exterior dash plastics in both 4Runners (American and mine) seem to be equal... Where's the room I don't have? I'm not able to see it.
American 4Runner (Mile's one)
Mine:
I have a little plastic pocket below the ash tray, and american 4Runners seem don't but where has the room of my 4Runner gone?
Anybody knows if the shape of the lower dash of american and european 4Runners are different? I'm getting a little confused...
David
Old 05-05-2005, 03:14 AM
Blizzard's Avatar
The size of Mile player and mine are the same? Mine is a standard size... DIN size.
I'm getting bored of seeing the two pics and looking for differences
David
Old 05-05-2005, 03:19 AM
Blizzard's Avatar
Mmmm I have a friend with a canadian imported 4Runner.
Seems that this plastic trim is narrower than mine isn't that?
Old 05-05-2005, 03:47 AM
Cebby's Avatar
Looks like your trim is thicker like you suggest. That is a small trim piece that you need to open it up. It only goes from around the heat controls and clock, down around the radio. Should be pretty inexpensive if bought used. It's light, so shippping should not be much - even to Barcelona.
Old 05-05-2005, 06:42 AM
Blizzard's Avatar
Thanks Cebby, I'll ask Jason (toyota parts dude) hehehehe.
Do you have some kind of website? Your 4Runner is one of the prettiest I've seen.
David
Old 05-05-2005, 08:14 AM
Cebby's Avatar
David
No site yet, but I'll put one together to chronicle my 1UZFE swap.
Old 05-05-2005, 08:21 AM
lee
lee's Avatar
if you want some webspace, mike, ill give ya mike.kidmoe.com or cebby.kidmoe.com or something.
let me know.
Old 05-05-2005, 10:20 AM
Blizzard's Avatar
Somebody can measure the width and the height labeled X and Y (Hole measures) for me? So I can make suppositions if one 7'' screen will fit hehe.
Thanks!
David
Old 05-05-2005, 11:05 AM
Cebby's Avatar
let me know.
Thanks Lee - I've got space, just no time...
Old 05-06-2005, 08:53 AM
Flamedx4's Avatar
A double DIN opening is not ACTUally double DIN = you can't put 2 DIN radios in it. Morelike 1 3/4.... I had to do some major surgery to get the inclinometer in there, I could only cut down the clinom just so far... I'd measure mine for you, but it's not stock size any more.
Old 05-06-2005, 09:32 AM
Blizzard's Avatar
Thanks Flamed, I suppose I'll take appart the screen case and leave only the screen itself.
I've seen them fitted in double dins so I think it's possible hehehe.
David
Old 05-06-2005, 10:09 AM
Flamedx4's Avatar
I trimmed out above and below the opening right to the dash structure. Probably took out 3/16" each. Then used a hot blade on a soldering iron to reshape the opening. My radio bracket is touching the bottom of the molded structural piece, and the inclinometer is touching the structure above, I cut the case to the point where it is exactly as high as the dials themselves. I could not take out another 1/16" of any part!
Old 05-06-2005, 11:04 AM
Gangus2006's Avatar
You sure? for ÅÅÅÅs and giggles I put a friend's IVA-D900 and the Alpine 5.1 Surround Processor in the 4Runner to see if it would fit, and it did. They were each DIN.
In case you were wondering, you have to remove the trim rings..
Old 05-06-2005, 12:54 PM
X-AWDriver's Avatar
The JDM/CDN models whole plastic piece extends further down then the USDM version by almost an inch. Look at the pics real well and you can tell.
Old 05-07-2005, 05:07 AM
Blizzard's Avatar
Thanks for your replies. When I have earned the money to buy a touch screen I'll buy an american type piece for the dash and put it in my truck.
David
Old 05-07-2005, 06:28 PM
Flamedx4's Avatar
Okay, I just measured mine. After I trimmed the opening as large as I could (as mentioned above) I have 4 3/16" of height.
Pic from when I was fitting the inclinometer-you can see inside the upper opening where the dash structure is (it's orange too because the dash was out when it was painted.) I trimmed the bottom in a similar manner and installed the stereo as low as I could get it.
Old 05-07-2005, 07:42 PM
leebee's Avatar
hey david!
i took a couple pix that included some dimensions, i hope these help.
Attached Thumbnails Center dashboard space-measurements-004.jpg   Center dashboard space-measurements-005.jpg
Old 05-08-2005, 11:16 AM
Blizzard's Avatar
Thanks to you both!
Now I must do some drawings and earn some $$$ hehehe
Thank you!
David
Old 05-09-2005, 09:07 AM
Babypig's Avatar
I can get two din radios in mine. Looks like you may have a din and a 1/2 radio though.
live4soccer7
05-11-2016 06:52 PM
primordialbeast117
12-19-2015 12:23 PM
Gravel Maker
RuffStuff
10-04-2015 10:26 AM
hiluxinargentina
09-30-2015 05:51 PM
Rickstwowheels
09-29-2015 02:23 PM
Quick Reply: Center dashboard space
