wheel bearings are shot...maybe..
Old May 3, 2005 | 01:19 PM
88yotaboy's Avatar
I think that my left front wheel bearings are shot. I went wheeling last friday and was climbing a realy steep hill when the front end started hopping and making noise.... and then when i got on the highway the steering felt funny. And now i noticed that the tire is showing signs of uneven wear beggining... Im guessing that the problem is the wheel bearings because just about everything else in the front end is new or doesnt show signs of damage. Can someone please tell me some info about wheel bearings?
Thanks,
Andy
Old May 3, 2005 | 01:31 PM
4Crawler's Avatar
This should cover it:
http://www.4x4wire.com/toyota/maintenance/front_end/
Old May 3, 2005 | 01:37 PM
88yotaboy's Avatar
that makes it sound easy.... how long should this repair take if i dont run into problems.... which i probably will but anyway... how long should it take?
Old May 3, 2005 | 01:58 PM
mt_goat's Avatar
Are you sure its not the CV?
Old May 3, 2005 | 02:03 PM
88yotaboy's Avatar
that cv happens to be less than a year old... and i could be wrong but i dont think a busted cv would cause poor 2wd handling and weird tire wear...
Old May 3, 2005 | 02:34 PM
mt_goat's Avatar
Unless you have manual hubs and they are unlocked the CVs still turn in 2WD.
Old May 3, 2005 | 03:39 PM
AgRunner06's Avatar
Since you would only be doing one side and have never done it before...I'd say it'll take 2-3 hrs. It takes me 2 hours to take everything apart down to the rotors on both sides. You don't have to separate the rotor from the hub so that saves some time. Just make sure you pack the new bearings well and put plenty of grease in there. You will need a new grease seal for your hub. It's really not a difficult job to do.
Good Luck
bigjstang
Jun 2, 2025 03:56 PM
glowz825
Jan 25, 2022 09:28 AM
Shaun Crystal Gomban
Aug 2, 2015 08:00 PM
RBK
Aug 1, 2015 01:55 PM
PlayAwhile
Jul 20, 2015 11:36 AM
