what choices do i have for a selectable locker?
Originally Posted by Tacoma Dude
I thought I read somewhere something about a manual cable locker?
your choices for a selectable locker are:
ARB RD23 + an air source like an ARB compressor
--or--
Toyota e-locker, but you will either need the cable conversion kit or the wiring instructions to get it to actuate. you will also need to modify the axle housing to get it to work which requires some drilling, tapping, grinding and welding.
either way, you will have other expenses. with the ARB, you can use your third member, but you will have to pay for the gears to be set up on the install. you can find the e-locker thirds with the gears in them, but the pinion flange is different for the 2nd gens, so you will need to have that modified and you will have to pay for the axle housing work unless you tackle that yourself.
TheBFA
Feb 15, 2020 06:55 AM
83yotastockR
11
Nov 10, 2015 06:54 AM
SpookyMulder
Nov 4, 2015 11:56 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
Toys4parts
Sep 26, 2015 01:56 PM
