1st gen short shifter?
Originally Posted by Tacoma750
Anyone make a short throw shifter for the 1st gen?
I'm also working on one, using the B&M shift kit for the Tacoma mated with a custom spacer. This would be an all new shifter so you don't have to send in your old shifter to get modified. It will cost more than Marlin's kit, but no down-time. I also have short throws for the transfer case:
http://www.4Crawler.com/4x4/ForSale/...wShifter.shtml
what tranny does my truck have? the vin tag says w46, however that tranny is a 4 speed, and the tranny in my truck is a 5 speed, also im 4x2..... would that make a difference in if i can have a short shifter made for me?
i know the shifter sticks are largely interchangeable between most L, G and W trannies. however the shifter bases are different and i think that's where the main problem of building a short shifter comes up. you have to modify the base to get less of a throw angle.
I'll just be making a spacer to go under the existing shifter base for my short shifter, same as I do for the t-case short thow kits I have been making for a few years now:
Ony difference is that the design of the tranny shifter does not lend itself to a bolt-on extension like the t-case does.
BTW: I can make a bolt on spacer for the tranny, only raises the shifters pivot point but does not change the throw. This could make a good solution for changing a 3" body lifted shifter into effectively a 2" lifted shifter. I actually stumbled upon this idea while trying to make a shorter throw. If anyone is interested, feel free to e-mail or PM me.
vanion2
Jul 29, 2015 06:17 PM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
Jul 6, 2015 04:07 AM
