Quick question Quick answer re CB
I intend on buying the Cobra 75 WX ST.
Will I gain anything by purchasing a Firestick adjustable end 5ft vs 4ft antenna?
I'm thinking longer means greater transmission/reception distances
Thanks,
Mark
PS does anyone use a 7ft antenna with flag off the roof of their truck? - great for use in dune areas - maybe not so good for tree-lined trails.
Thanks,
Mark
you can buy the meter for $20 @ radio shack or jcwhitney and it comes with instructions....
if your cb isnt tuned properly, it might lead to failure... i never tuned my old setup and i had a 5 mile range in the city.... but i cant gurantee yours wont blow up...
bob
Co-Founder/Administrator
The adjustable ones like the Firestik II that I have, and there are some Wilsons out now that have the adjustable tip too that make tuning easy.
Makes it really easy to adjust your SWR.
My Cobra has a built in SWR meter, so it is a snap to get it done.
I am just a hair over 1 on all 40 channels.
Here is an example of a 4' antenna.
You sure you wanna go higher?
I would imagine it could happen but I don't think anyone not running a modified CB or extra power would EVER have to worry about it. Technically speaking it could happen, with high SWR's but I personally have never had it happen or know anyone who has. I had a pretty big radio and run it forever before I got it tuned. Also it wasn't off very much either.
Originally Posted by epic37311
Doesent the 75 have a SWR meter built into it?
Thanks for the replies.
Years ago (25+) when I fooled around with cb in cars, we used to make a metal plate to mount the antenna on and then use some U bolts to mount it onto the roof racks (luggage rails).
Does the antenna have to be grounded (bolted in) to the roof to get the benefit of the roof plane or by simply being within the proximity of the roof does this still allow the roof to act as a plane? - No...I am not intending to mount my antenna on the roof but would consider the roof rack if that worked. Otherwise I'll experiment with the traditional fender or rear bumper placement.
Thanks
Mark
Thanks
Mark
I was under the impression that the ground plane was also directional. In other words placing the antenna in the centre of the roof would give the best multi-directional reception as opposed to having it one end which would be more one dimensional.
Any ideas on this?
Thanks
Mark
Any ideas on this?
Thanks
Mark
There seems to be some cross posting so rather than jumping backwards and forwards I will differ to this post...
https://www.yotatech.com/forums/f97/wilson-firestik-ii-53735/
which seems to answer some of my questions I just posted anyway.
Interesting link provided about the relative dB gain comparison between the Firestick and the Wilson.
this should answer most of your basic CB needs... http://www.firestik.com/Tech_Docs.htm
4Runnin2000
Jul 29, 2015 06:09 PM
icentropy
Jul 14, 2015 10:23 AM
But alot of people don't have a meter or know how to tune.
