Wierd leak under my rig, couldnt be my rig though
Old Jan 26, 2005 | 12:30 AM
Yoter's Avatar
Guest
Thumbs down Wierd leak under my rig, couldnt be my rig though
So today i am mounting my back up lamps when I glance down at the ground under the passenger rear of my axle. I see a 12x7" diameter puddle of goldish fluid. I ofcourse touch it and feel it and sniff it. Looks, feels, and smells like brake fluid. My brake fluid is down but I see NO leak anywhere. Its very dry under the rig right now. I am wondering if I have a brake cylinder going out in the passenger rear drum. I would think that it could leak and dry pretty fast coming off the rubber tire but once on the ground it would puddle up. Very odd though.
Attached Thumbnails Wierd leak under my rig, couldnt be my rig though-leaking.jpg
Old Jan 26, 2005 | 12:57 AM
neil_P_smith's Avatar
Talking keep lookin
i think that you would see a "water" mark on the tire if it was coming from there. is it your proportion valve at the bottom of the rig. Look for a shinny or cleaner spot. Just keep looking it is coming from somewhere. Or dose someone ells park there ever. Look and see if you can tell if it a recurring stain on the concrete. good luck
Old Jan 26, 2005 | 08:38 AM
Yoter's Avatar
Guest
No the person that spot belongs to is blind and takes the bus. But she has been gone for months in cali so none of her friends have been parking there. Also the puddle looks fresh and the rig is so dry down unduh that it would be simple to see a leak stain. I am going to look again in better day light. I will prolly run down and let Jiffy lube top off the brake fluid being thats not a huge job for them or is it. lol I will keep you posted.
Old Jan 26, 2005 | 08:39 AM
Glenn's Avatar
Maybe it's dog urine. That is a LOT of brake fluid to be leaking out to be down a little.
Old Jan 26, 2005 | 08:40 AM
Babypig's Avatar
Stick a piece of cardboard under it and let it sit and see what happens.
Old Jan 26, 2005 | 08:46 AM
Yoter's Avatar
Guest
does dog urine have the brake fluid taste?
Old Jan 26, 2005 | 09:55 AM
eric-the-red's Avatar
That's one of those things that everyone has to discover for themselves
As someone else said that looks like a lot of fluid. I would think your master cylinder would be empty. Maybe get someone to stand on the brake pedal to put some pressure in the system and look to see if anything is leaking out.
Old Jan 26, 2005 | 09:57 AM
its2slo's Avatar
sabatoge!
Old Jan 26, 2005 | 10:08 AM
TacomaTRD's Avatar
I can't believe you need to take your truck to Jiffy lube to have brake fuild added/checked... Besides, if the puddle is that big I wouldn't be driving it far before I looked at the resivour...
So was/is it low?
Old Jan 26, 2005 | 10:40 AM
95ToyotaPU007's Avatar
I would pour some water on it to see if it mixes. If it mixes you know it ain't oil based and is possibly not brake fluid. If beads form then it is oil based. Because I'm a pyro I would throw a match at it and see if it lights up.
Old Jan 26, 2005 | 05:41 PM
Yoter's Avatar
Guest
My brake pressure is fine today. the level is barely low. im thinking some punk parked in the spot I stole and leaked on it. damn punks
Old Jan 27, 2005 | 09:32 AM
Doc279's Avatar
Her we go with the punk thing again. I looked over to see a punk, I said whats up punk and the punk ignored me - His punk ass just drove off with me saying " whats up punk ! damn punks
What does dog piss taste like ? - what does brake fluid taste like ?
Old Mar 6, 2010 | 01:18 PM
stevenazevedo00's Avatar
i have the same problem the seal was shot on the proportion valve i thought i was leaking fluid out of the brake cylinder also and i thought my shocks where bad too because it was leaking on them ahhhh!
pretty dumb i know i ordered shocks and a brake cylinder like a jackass and found out it was niether but it was the proportioning valve i went to a toyota parts dealer and picked up a used one and it was clean externally but internally what a nightmare (water damage) so know we believe its clogged with rust and is not getting fluid through.. i think? god what a pain in the ass this is...
anyone's help would be great i dont know how to start a blog or whatever
Team420
Dec 30, 2015 01:31 PM
itzmywife's
Jul 25, 2015 04:55 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
andrewtexas123
Jul 14, 2015 04:29 AM
Avenged
Jul 9, 2015 07:55 AM
