FROR trans/tcase mount and skid install (pics)
thought i'd post up some pics of the install of my new trans/tcase mounts with skid plate. Bought it from Front Range Offroad Fabrication . They shipped real quick, no problems with the customer service.
Its really beefy, the pictures on the website dont do it justice till you hold onto it. This thing is bulletproof. I'm going to take it to have the end pieces welded on this week hopefully. I'll post up what i thought of the install. It comes already powder coated in a very nice copper color.
I got the crossmember installed last weekend, was very easy. I would expect with a stock setup the installation time would be less than an hour from start to finish. Mine took somewhat longer since my motor/trans/tcase was not PERFECTLY square relative to the frame due to the booty fabbed motor mounts i had made to place the supra motor, I cut them off and am in the process of making stronger ones that sit level and square
I didnt have my camera with me at the time and the truck is now off getting the new motor mounts and sliders fabbed up but ill post some after it comes back (if the damn weather ever lets up, its always freezing cold and snowing/icing whenever there is time to get things done
)Chris
I like my FROR x-member+skid-plate, been running it for almost 5 years now, love the added clearance underneath with the drivetrain lift:
http://www.4Crawler.com/4x4/CheapTri...aseCrossmember
Went front this sort of "belly":
To this:
To this:
Unbelievable change, gaining 5.5" under the truck with no change in tire size, it is a whole different rig.
Here was a picture of the sort of things I used to get high-centered on, a ledge hardly half a tire high, maybe a 16" drop:
Now I can cruise over stuff like this:
I do hit the underside of the truck from time to time, but only rarely get hung up now, usually just slide over whatever I hit, sometimes w/o even knowing it, until I see the deep scratches in the powercoating on the skid plate later.
Originally Posted by waskillywabbit
Seems like I read that the FROR t-case cross member/skid wouldn't work w/ dual cases and caused problems w/ the t-case mounted e-brake?
im going to use an electronic line lock on the rear disc brakes for an e-brake, the calipers i am using dont have an integrated parking brake
Thanks Roger! I've tried to explain the advantages to others without knowing first hand the substantial difference it's going to make, but it's hard for some to understand that gaining 5.5" like you mention is like going from a 33" tire to a 44" tire or going from 3" of lift to 8.5" of lift. What's nice is that this mod can achieved with only a 3" body lift and motor mount spacers directly from you.
Another thought for those wanting to keep a very low height to their rig is why not do a 3" body, no suspension lift, and do the drivetrain lift and gas tank relocation which will net them 2.5" more undercarriage clearance, yet be 1" lower than what most people do with a 3" suspension and 1" body lift? Just an idea!
Chris
Chris
thats all true, but you still have to improve your differential clearance as well, which can only come from larger tires. Having underbelly clearance is one step, but not having to dragging your axle over everything is important as well. Picking good lines helps, but isnt always going to work.
Chris
You bet, that makes a huge difference by itself:
http://www.4crawler.com/4x4/CheapTri...tml#Clearanced
The old axle bottom and the shaved one:
