Best location for new oil sender (Autometer oil pressure gauge)
Old Oct 17, 2004 | 11:41 PM
Bob_98SR5's Avatar
Hey guys,
I'm getting ready to install my Autometer oil pressure sending gauge (#2634). Its electric, so no oil line coming into the cabin.
Which location is best to install the supplied oil pressure sender? A1 or A2? A1 looks easier because its relatively straight line with the wheel well access "hole" (the same hole I use to remove the oil filter)
For reference, "S" is the stock oil pressure sender
Also, I read that these two little 8mm allen bolts are loctite'd. what's the best way to de-loctite it? hopefully not heat b/c i dont have a torch!
thanks,
bob
Old Oct 18, 2004 | 05:49 AM
instigator's Avatar
Bob those plugs are also british pipe threads, but you could get a 3/8 pipe(us) to work. i plumbed my bypass filter from port A2 on you pic
Old Oct 18, 2004 | 10:05 AM
Bob_98SR5's Avatar
instigator,
ok great. thanks for the info. that A2 one looks rusty. i read that both are a b###h to get out. maybe i'll try A1 since it doesnt look as rusted
bob
Old Oct 18, 2004 | 11:04 AM
NorCalVP's Avatar
Originally Posted by Bob_98SR5
Hey guys,
thanks,
bob
Bob, I've also got mine on A2, this is on my Tacoma though...
Steve
Old Oct 18, 2004 | 03:09 PM
Bob_98SR5's Avatar
Steve,
Ok, thanks. Looks like A2 it is!
Bob
Old Oct 18, 2004 | 05:46 PM
FattyCBR's Avatar
A2 is where I have mine, also A1 is the oil pump so I would not tap into it. Good pic BTW, best I've seen of that area.
Old Oct 19, 2004 | 12:47 AM
Bob_98SR5's Avatar
Fatty,
Thanks for the warning re A1. I thought that there were two plugs you could tap next to the oil sender unit. I guess I read incorrectly.
(phew!)
Bob
Old Oct 19, 2004 | 05:41 AM
EnolaGaia's Avatar
I agree about it being the best photo I've seen on a Toyota forum...
But I'm wondering (just for the record) - what's the problem with using A1 'cause it's on the oil pump? Erroneous readings? Failure risk? Bad karma?...
Old Oct 19, 2004 | 03:16 PM
superjoe83's Avatar
i believe if you take that plug out, it will be followed by a spring and a ball, thats most likely the pressure relief valve for the pump
Old Oct 20, 2004 | 09:07 AM
EnolaGaia's Avatar
OK - I see... Thanx for the clarification....
Old Oct 20, 2004 | 02:13 PM
kevin444's Avatar
how the install went? any pics of the gauge in action?
bigjstang
Jun 2, 2025 03:56 PM
Jdgarrison
Oct 1, 2015 05:22 PM
Sep 4, 2015 09:27 AM
88yodabasket
Jul 13, 2015 01:32 PM
Poncho0206
Jul 10, 2015 06:21 PM
