Turn signal/Brake light wiring question
Does anyone know how I can wire the turn signal to my brake/tail light on my 2000 Runner? I'm doing something custom on my rear lights. I already tried connecting them together by tapping the turn signal into the tail/brake and it all works fine until I hit the brakes. Then the turn signal stops and the light stays steady. My question...is there a way I can get this to work with some sort of relay or something??
TIA
Paul
TIA
Paul
Originally Posted by Unhappy99
Assuming you don't have the factory trailer wiring, or that its bad, the simplest and most cost effective solution is to go to an auto parts store, Uhaul, or kwikhitch and get the harness and converter.
$35 or $40 solves the problem.
Unless your talking about adding a harness between my factory trailer wiring and my lights on the truck?
It accomplishes the same thing, which is converting your independent turn and brake signals to a combination brake-turn signal. Or did I misunderstand your original question?
This cannot be accomplished by one relay. You need an 'exclusive or' gate (CD4070) driving a PMOS power transistor to switch voltage. This is exactly what the trailer converters do, with some added short and/or reverse circuit protection.
If you have the factory trailer wiring, then just disconnect your brake light wire and attach the trailer wiring brake/turn wire to your brake light. Done!
I understand what your saying and it makes sense. I looked under my truck and I have a plug to connect trailer wires to(yellow, green, brown and white)labeled ground, brake, L turn, & R turn. Do I still need the converter and then splice into the wires that come out of that or are these wires already converted?
Nope. If you have the external wiring plug, then you already have the converter, lets hope it still works. Just open up the left rear interior panel and adjust your wiring accordingly.
This thread has more info. Start reading about 2/3rds the way down where the photos are.
Awesome! Thanks. I'll try it this weekend
"to(yellow, green, brown and white)labeled ground, brake, L turn, & R turn."
This should not be the case. It should be:
White: Ground
Brown: Tail lights
Yellow: Left Turn/brake
Green: Right Turn/brake
White: Ground
Brown: Tail lights
White: Ground
Brown: Tail lights
White: Ground
Brown: Tail lights
Ok...this is what I have so far:
I have everything listed as in the other post as far as having the converter and the correct wires.
I cut the turn signal wires completely and left them alone.
I then cut and spliced the green w/white stripe (brake light wire from bulb) into the yellow from the converter.
I then cut and spliced the same color wire on the RT side to the green wire from the converter.
Here's what I have. Brake lights, turns, hazards and tails work fine. My issue is now when hitting the brakes, all it does is flash faster when I have the turns on....
...soooo....I know I'm missing something here or have my splices and/or cuts wrong??
So it all works correctly, right? Except that turn signal flashes a bit faster when the brakes are on?
This would be because power for the flashing bulb is coming from both the brake power feed and turn power feed. There is a current sensor in the turn signal power feed, not enough current draw, and it flashes faster than normal, to let you know it thinks you have a burned out bulb.
Solution? Hmmmm....attach a second bulb or power resistor in parallel with your existing bulbs to increase current draw. 10 to 20 ohms and 10Watts would do it. Not graceful, but would work.
I would be inclined to try a 6 amp diode or two in series with the brake power feed going into the converter. Then the preferred current path would be from the turn signal power feed. The brake lights would be a bit dimmer, about the same as they are when the engine is not running.
I don't know if there is a current sensor on the brake feed, if so, then adding a diode or two in series might cause a failed brake light indicator to come on, if there is such a thing on the 4Runner.
Or, just live with it....
p.s. Could also try replacing the flasher with a different one. Autozone sells them for $8 or so, and it may have different current sensing characteristics.
Brake Lights
A light came on in the dashboard of my Toyota (2000 Solara) which is for the brake lights. My friend observed that in fact my right rear brake light was out. However, the light off the dashboard has disappeared for short periods of time over the past 2 weeks.
When the car is off and I hit the brake, the brake light works, and the guy at Autozone took a look at the light bulb and said it looks good. Is this a wiring issue????
Jun 1, 2021 01:51 PM
Avenged
Jul 9, 2015 07:55 AM
