i got a LOT of questions and messages about how i did the air intake on my 3rz swap in my 87 4runner. i kept the air intake on the passenger side and swapped the battery to the driver side. it is a short intake with most of the baffles removed. i used the factory tube that crosses over the valve cover becuase it uses a bracket to the side of the head for stability, which is adapted to a 70 - 80mm silicone adaptor, to the MAF, and then straight to a cone filter. this is a simply setup and doesnt take up much space. this should be exactly what marlins son has on his rig also. here are part numbers.
intake plenum to intake sub assembly boot and clamps
1788275040
9611110800
