All Other Toyota Swaps I4, I6, Lexus V8
22re to 3rz air intake guide
Old Jun 24, 2025 | 08:42 AM
keycw's Avatar
5 Year Member
i got a LOT of questions and messages about how i did the air intake on my 3rz swap in my 87 4runner. i kept the air intake on the passenger side and swapped the battery to the driver side. it is a short intake with most of the baffles removed. i used the factory tube that crosses over the valve cover becuase it uses a bracket to the side of the head for stability, which is adapted to a 70 - 80mm silicone adaptor, to the MAF, and then straight to a cone filter. this is a simply setup and doesnt take up much space. this should be exactly what marlins son has on his rig also. here are part numbers.
intake plenum to intake sub assembly boot and clamps
1788275040
9611110800
intake sub assembly
1780575100
sub assembly bracket to engine head
1787175011
70mm-80mm silicone adaptor (amazon)
OEM mass airflow
toyota 3rz MAF to cone filter adaptor (amazon)
Riplayne
Feb 28, 2019 10:52 AM
kfarrar
Apr 20, 2012 07:00 AM
TheVandMan
Jul 31, 2007 08:51 PM
thegreydog
Apr 11, 2007 03:15 PM
slammdrider
May 7, 2004 05:20 AM
