Idle Fuel Cut Solenoid Diagnostics
Old Feb 26, 2025 | 10:25 PM
Moniker's Avatar
How exactly do I test the idle fuel cut solenoid by giving it power/energizing it? I don't quite understand what others have said about this. I have a multimeter if that helps. Thanks
1990 Hilux with Carb 22R
Old Feb 27, 2025 | 02:24 AM
prcnctoyo's Avatar
Old Feb 27, 2025 | 09:45 AM
Moniker's Avatar
What is the lead that connects the two terminals and where would I source it?
Old Feb 27, 2025 | 09:54 AM
Moniker's Avatar
What book is this screenshot from?
Old Feb 27, 2025 | 10:46 AM
Jimkola's Avatar
YT Community Team
5 Year Member
I use test wires that have small alligator clips at either end. You can buy them by the bag for cheap.
Old Feb 27, 2025 | 01:03 PM
prcnctoyo's Avatar
The screenshot is from the FSM (factory service manual). You can download one from this link.
https://web.archive.org/web/20110102...ttora.com/FSM/
Old Mar 2, 2025 | 06:14 PM
Moniker's Avatar
Dumb question: I assume small alligator clips are okay because it is not required that they be attached to the battery terminal itself and can go on the terminal clamp like various wires with ring terminals?
Old Mar 2, 2025 | 06:15 PM
Moniker's Avatar
Thanks this will be really useful.
Old Mar 3, 2025 | 07:07 AM
Jimkola's Avatar
YT Community Team
5 Year Member
Yep. You don't need a bolted in connection for testing lioke this
J_W
Feb 1, 2024 07:45 AM
C17loadclear
Sep 30, 2014 03:31 PM
Rebelson
Sep 19, 2010 11:18 AM
NorCalWheeler
Mar 13, 2009 07:46 AM
