Dieseling 22R
Old Mar 12, 2009 | 09:00 PM
NorCalWheeler's Avatar
Dieseling 22R
So a week ago my truck wouldn't idle so after taking it to auto shop at school we figured out it was the fuel cut solonoid(SP?). After taking it out we found a metal shaving in it so we cleaned it out and it would idle. But now when I turn it off it trying to keep running. We messed with the idle screw but it still does it. Can someone please help? By the way it's a 22R in an 86 Pickup with nothing done to the motor
Old Mar 12, 2009 | 09:09 PM
myyota's Avatar
There is a small o-ring at the end of the fuel cut solenoid, if its missing that will cause the dieseling that your getting, if the o-ring is there and your still getting the dieseling problem then the fuel cut solenoid might be bad and turning the fuel flow off when you shut the engine off. I went through this same problem on a 22R that i used to own.
Old Mar 12, 2009 | 09:20 PM
where did you get the new fuel cut solenoid?
Old Mar 13, 2009 | 06:02 AM
ozziesironmanoffroad's Avatar
sorry for the hijack, but isnt that how the fuel cut solenoid is supposed to work? kill the power, it cuts fuel?
Old Mar 13, 2009 | 07:42 AM
myyota's Avatar
Yes, thats how it is supposed to work, but if the o-ring is missing then fuel can still get around the fuel cut solenoid and cause dieseling.
Old Mar 13, 2009 | 07:46 AM
myyota's Avatar
If i remember right the fuel cut solenoid was a bit expensive new, but i was lucky enough to find a used one. if you have a pic n pull near you then you could probably find one there.
buckz6319
Aug 5, 2017 03:50 AM
Iceman4193
Oct 16, 2015 10:50 AM
alexcarey
Oct 14, 2015 06:05 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
Toys4parts
Sep 26, 2015 01:56 PM
